Question about Marantz Audio Players & Recorders
I have a Marantz 2270 receiver and a Marantz 2220B receiver that have the same problem. At about 1/2 volume on either unit with Bass rich music, I get a loud cracking/ popping sound that actually sounds bad for the speakers. I tried both receivers on 3 different sets of speakers and the cracking/ popping noise was quite evident at about 1/2 volume at the bass parts. The pots were cleaned but the noise is still there.
    President:
  • 1,851 Answers
This kind of problem is logical, if you have the "loudness" control enabled. Well, let me explain the situation. The loudness control is a function that boosts the lower and higher frequencies (the bass and treble) in low volume settings. This is useful because at low volume settings our ears are not so sensible at these frequencies, so the result is nice to hear. This boost (the loudness) stops automatically (at most amplifiers) at volume settings just above the middle of the volume control (to be more specific near the 1 hour setting of the volume knob), that's the point that you get this cracking sound. In case the audio source has plenty of bass frequencies the result is what you hear.
I suggest you to lower the bass boost potentiometer or disable the loudness control when you hear music at these volume levels. A good idea also is to disable the loudness control permanently and boost the bass and treble from the knobs as you wish. This will give you a sound near the original one although at the beginning you will feel the absence of bass (this is because the sound you were listening before has more bass).
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Mar 19, 2011
Marantz SR-66 Shut down!
Sounds like the protection circuit is tripping. With power off, check for loose speaker connections. Also, look very closely for shorts in the speaker wires. Even a single loose strand can touch another connection and create a short, which shuts down the receiver.
I would take take the frequency splitter out of the circuit and see what happens. Check for acceptable impedances in the manual. The receiver may not like the load the splitter presents.
The receiver may have settings for bi-amping. Then you use one set of terminals on the back for treble, and a different set for bass.
Feb 03, 2015 | Marantz SR-66
There is a crackle when i turn the volume knob.
First unplug it. Sounds like you need to spray some tuner cleaner in the pots that are crackling. Pull the knob off and you should be able to use a spray can of tuner cleaner with the straw that comes with them to spray into the potentiometer , then rotate the pot several times while it is still wet. After cleaning them all, wait 10 minutes and then try.
Jan 09, 2014 | Marantz Vintage Model 2220b Stereophonic...
Marantz 2220b does not play in stereo in fm mode. i doxed all pots, & knobs, adjusted pot 304 but no dice. fm light is good, lites up on aux settings
Do you have an antenna attached to the receiver? If you don't, it might not be getting a powerful enough signal to pull in stereo. Also make sure that the mono button is not pressed or faulty.
Aug 26, 2013 | Marantz Vintage Model 2220b Stereophonic...
MARANTZ MA 700 NOT SURE HOW TO MAKE CONNECTIONS. NO MANUEL. LIGHTS UP
you'll want to use the rca sub out from your pioneer, to almost any input (aux, tape, cd) of the marantz, then speaker cable from marantz to sub. once you get them hooked up, adjust volume, bass, on the marantz to blend well with main speakers at a nominal lvl,
Mar 20, 2013 | Audio Players & Recorders
Where i can get an marantz pm493 amp volume knob also on the amp bass trible is now working and only 1 side speaker power is working any idea what is wrong..
you can get the know right from the dealer at this link http://us.marantz.com/us/Support/Pages/ServiceCenter.aspx as far as the one speaker working, switch the speakers to make sure its the unit and not the speaker box, if that doesn't help you probably have a blown output in the unit itself,, since its a Marantz Its worth the cost of having it repaired,, as with all High end receivers or amps, Be sure the unit is in the off position before you attach or disconnect any speakers ,, if they short out,, our gonna blow the output
May 21, 2011 | Audio Players & Recorders
Marantz 2220B with Sound Problem at Half volume
The most likely cause of this is some DC current working its way through the system. WIthout taking some measurements, it will be difficult to confirm this though. This should not be an expensive repair. Figure on $20 or so for parts (capacitors mostly).
Dan
Apr 12, 2009 | Marantz Audio Players & Recorders
My Marantz 2270 gives off a crackling sound through my Infinity sm-115 speakers anytime there is a lot of bass in a song. What do I need to do to fix this problem. I'm almost positive it is the reciever...
It sounds like one or more of the channels is letting some DC current through or that the front end is breaking down. In either case, the parts required to fix it are generically available and cheap. Figure on $10-$20 in parts at any shop that deals with audio components. One thing you can do to help narrow this down is to see whether the behavior changes with heat. Do you get the same results upon startup? Does the problem get worse as the unit works (gets warm)?
Dan
Feb 22, 2009 | Marantz Audio Players & Recorders
The lights are on the other side of the display. They have a plastic "wave guide" that deflects the light where needed. I hope this helps...accordianman
Jun 14, 2008 | Audio Players & Recorders
251 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
