Question about TMC M4810 NON-KSU Corded Telephone
Door wont open when press the buttom - TMC M4810 NON-KSU Corded Telephone
Hi, there is 1 # 1 Phillips screw you must unscrew before you slid this cover off.
Posted on Nov 08, 2008
Need to fix problems with 5104 viper remote
It is possible that you need to reprogram the remote.
1st you need to enter the remote into programming... Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to receive confirmation and then release the button and the turn off the key .
Remote should be program
Jan 21, 2013 | Viper Televison & Video
The driver's side door could not be opened inside with interior handle. I have a 2002 volvo v70. Everthing seems ok before I pressed the central locking buttom at driver door armrest. Now the driver door...
you"ll have to remove the door trim and replace or reposition the cable/rod assembly that has move out of position not too hard to fix dont worry
Jun 05, 2010 | 2001 Volvo S60
How to program in the 3 pre sets for garage door openers We have a 2001 dodge grand caravan es
Hope this a Homelink. Put new batt in garage door remote. Park outside garage. #(1) Press & hold 2 outer buttons on Homelink. Release ONLY after light starts to flash. Don't hold for longer than 30 sec. Don't repeat to program the other 2. #(2) Hold the remote 3 inches from Homelink. #(3) Press & hold the Homelink buttom & the remote button at the same time. #(4)The Homelink will begin to flash slowly then rapidly. After the Homelink flashes rapidly release the buttoms. #(5) Press the just trained Homelink button if the light stays on constantly, programming is complete..... To program the other 2 links DO NOT REPEAT #1
Jan 10, 2010 | 2001 Dodge Grand Caravan
Door well not open
hit the top of the consel were the disk drive is it could just be dusty and has 2much friction to move on its own. if that still dosent work then push the buttom to open it and get a thin object (like a butter knife or sum that wont damage the consel) and use leverage to open it but make sure the consel is trying to open it itself or else you will jam the gears if you dont do it rite
Dec 15, 2009 | Microsoft Xbox 360 Console
Dimension4 micoweave oven door will not open. I heard a sound like piece of plastic dorping and oven door stayed closed after I pushed on the open buttom
door asembly has collapsed as you might have guessed. Bit of a job to get it open without removing the whole outside coverings, even then it wont be easy. You will have to replace the assembly anyway, and it might be easier to get it serviced at a specialist shop. Labor cists are the biggest outlay here as the assembly lock is about $60 if i recall correctly
Aug 14, 2009 | Microwave Ovens
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
Garage door opener transmitter/receiver compatibility
Press and hold the homelink button and wait till the red light flashes slowly,but don't release it. Now hold a working remote 3 inches away,press the remote button and hold it.When the red Homelink buttom fllashes quickly, release both buttons. Now go to the opener and push the learn button. Now go back to your car and press and hold the Homelink button. You will see the lights on your opener flash. Now your Homelink button should operate your garage door.
Jan 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a bell express vu remote that i am trying to get to work with one of your tv's. the remote is a 3.2IR the model number of the tv is 20pt634v37or 2opt634v37 can u please help me figure out wut the...
5-Press record
Finish :)
Jan 06, 2009 | Directed 434MHZ Remote Control
Remote codes
5-Press record
Jan 03, 2009 | Bell SH50102 Remote Control
Bell express vu remote codes for soyo tv
5-Press record
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
Lands Phones Logo
70 people viewed this question
Top TMC Lands Phones Experts
Are you a TMC Lands Phone Expert? Answer questions, earn points and help others
