Question about Ovens
Dirt and grease between glass in oven door
I have a Frigidaire smooth top stove about a year old. There is dirt(looks like lint) and grease between the glass in the oven door. It looks bad. Is there a safe way to clean it out? Brand new stove (one month) There is a leak in between the glass doors, how can this be clean
  • Anonymous Oct 29, 2008
    I have the same problem
  • Anonymous Mar 13, 2009
    i have the same problem.
I have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Posted on Oct 15, 2008
I have a Frigidaire Caprice double oven, 45 years old, the inner glass panel on the top oven door has shattered. I am not having any luck with finding replacement glass, any ideas?
take a profile of the glass shape (cut out the shape from cardboard) and go to a glass supply shop ( glass windows , doors , shower screens etc)
they should be able to cut and then temper the glass to make it heat proof for the door
if they cannot temper it they should be able to tell you where you can get it done
Nov 12, 2016 | Frigidaire Ovens
I have a separate OVEN under my cook top how do I clean the oven door glass it is a Frigidaire
Hello Elaine
Use a proprietary oven cleaner like Easy Off. Spray it, leave it on and wash off with a damp cloth. If the dirt is between the two glass panels of outer and inner door, you have to undo the screws and split the door.
Incidentally, you can fully edit your own posts, if you notice an error by going back to your post and click 'Edit'.
As moderator, I have altered it for you to help others looking for the same problem. We have to use our Edit tool sparingly as it involves work for the site admin as they check what Mods have altered.
Comment if you need any further help.
Jun 19, 2016 | Frigidaire Ovens
How do i clean the inside the glass on my oven door
The door usually has about 4 to 8 screws on the inside. Remove the door first by opening it to 45' and lift it off its hinges. Sit it on top of the stove carefully after putting an old towel and a garbage bag on top of it. Remove the screws in the door and the inside will lift off the outside skin. Clean the glass with oven cleaner and reassemble. Ours needs doing too!
Feb 11, 2016 | Ovens
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
La Germania oven won't stay lit. Stove is 10 years old and problem just started. It will light, but goes off after a few seconds.
Use a good air gun to blow off dirt inthe regulator. dirt in the nozzle and the burners.
Use a good brush to assist, or a thin metal wire to push through the gas passage .The air mixing section must be fitting correctly wedged.
Sep 11, 2010 | Ovens
How do you clean the inside glass on the oven door
You need to take the door off and apart. Glass is very hard to clean as the dirt bakes on it, so if you want it to look like new then just buy a new piece of glass.
Jun 05, 2010 | KitchenAid KEMC308 Electric Double Oven
I cant clean my glass on my stove where do i take it apart. i tryed the 3 screws on top put i still cant take it out ( the glass part)
put the door down, and unscrew all the screws inside the oven door. Be prepared for the door to come apart as you come to the last few screws.
Nov 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Glass cracked on smooth top stove would like to know if I can replace it myself model #FEF366DSB Frigidaire
Usually short instructions come with the glass. Just be careful about the wires not to pinch them tween the new glass and the frame. Use the type sealant they recommend.
Mar 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
705 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
