Question about Naxa Electronics Nca-675
I i hook red to red and yellow to yellow i have no power to my naxa nca-675. but if i revers the yellow to red and red to yellow i have power for a bit, were my screen lights up for a sec and the little red light behind the face is on but flashing. all the fuses are good in both car and radio, i have a 1994 bmw 318 is. i got the radio used with no owners manual. if you can help that would be awsome.
  • 1,940 Answers
Yellow is your constant +12 volt wire, and red is your switched +12 volt wire. It sounds like either your Red or Yellow wire isn't supplying the +12 volts it needs to. Only one of the wires is supplying voltage. You will need a multi-meter to check the voltage coming out of the Red and Ground, and the Yellow and Ground. The Yellow wire should have +12 volts at all times, even without the key. The Red wire should only have +12 volts with the key in the cylinder, and pointed to On. Find the wire that isn't supplying 12 volts, determine if it is switched, or constant, and then find a 12 volt wire that is switched or constant, depending on your findings.
Posted on Mar 14, 2011
Need to hook up a steering wheel control interface 2002 z28 camaro
Hello! Here is steering wheel print...NCA=No color Assigned...Yellow to fuse...Blue to Radio...
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
Guru...saailer
Jan 18, 2012 | PAC Audio Car Audio & Video
When i put on the face of my naxa NCA-675 radio it just flashes welcome and never lets me listen to anything. how do i fix it?
Mine is doing the exact same thing just bought it brand new a week ago I hope some one solve this
Aug 03, 2011 | Naxa Electronics Nca-675
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
My naxa nca-675 was working fine for about 2 weeks and then all of a sudden I notice the "Welcome" would flash and no buttons will work. Has the radio some kind of way locked? There shouldn't be...
I would recommend disconnecting your battery and see if that helps. As far as the owner's manual, it is worthless by far. It does recommend however, to press the reset button but does not clearly specify how to accomplish that.
Feb 02, 2011 | Naxa Electronics Nca-675
Naxa NX-984 red microphone does not work. How
If you got it recently, you can check to see if the store offers any kind of return policy. If it does not, or enough time has passed that you don't qualify for it, you can also try Naxa's 90 day manufacturer's warranty. Check the support page here for the specifics of the warranty and the contact info.
http://www.naxa.com/newsite/support.html
Mar 05, 2010 | Naxa Electronics Naxa NX-982 Dynamic...
I just installed my Naxa NX-670, and now when I attach the faceplate, nothing works.
If you run into this problem, be sure that all the fuses to the wiring leading from the battery to the radio are good, then be sure that the yellow wire is attached to the constant power source and the red wire is attached to the acc/ignition power source.
Oct 22, 2009 | Naxa Electronics NX-670 Car CD/ MP3 Player
My tv only has a cable hook up how do i hook a dvd player with red white and yellow cords
put the tv on av
#yellow cord in yellow socket
#red cord in red socket
#white cord in withe socket
now power the dvd
#Yellow cord in yellow socket
there will be 2 places for the red and white cords
#the red and white cords must be inserted in the audio,
# you will see them next 2 each other
insert them you it will work.
For More Info Email To ruanelectronics@gmail.com
May 11, 2009 | GE 32GT740 32" TV
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Naxa Electronics Nca-675 Logo
50 people viewed this question
Top Naxa Electronics Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Are you a Naxa Electronics Car Audio and Video Expert? Answer questions, earn points and help others
