Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
15" Powerbook keeps turning off
I have difficulty turning it on initially. Sometimes removing the battery helps. Once on it often turns itself off instead of sleeping, even when the power cord is connected. Occasionally it gets very hot in the area of the on/off switch. Could this be a battery problem? I've never replaced it in 4 years.
    Problem Solver:
  • 14 Answers
Check and see if its part of the powerbook battery recall
that way its a free new battery after ruling out the battery
the cpu fan would be my next choice.
Posted on Aug 10, 2008
Everytime I login to my Mac PowerBook G4 the screen shows logging in and then after about 30 seconds it goes back to login screen
HELLO
FOR SOLVE THIS ..Starting your Mac in safe mode does the following: ... Start or restart your Mac, thenimmediately press and hold the Shift ... If your startup disk is encrypted with FileVault, you might be asked to log in twice: once to unlock the startup disk, ... If the issue comes back, you might have incompatible login items. 1 800 726 0294 Apple Support Number Mac Technical Support Help Apple Customer Support Number 1 800 726 0294 Mac Help USA https://plus.google.com/u/1/116937682228750782866 APPLE SUPPORT NUMBER
Sep 09, 2017 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Display won't turn back on
You may need to open it up again and remove first the airport card and turn it back on and if that boot your computer there's a possibility that your airport is causing the problem and the airport may be loose and touching some other parts on it.
Hope that helps...........
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook g4 will not start on battery tho battery is fully charged. Will start on AC.
Are the contacts for the battery on the laptop good, no corrosion or anything?
Jun 04, 2012 | Apple PowerBook G4 Mac Notebook
My apple powerbook display is just showing blank. I had turned the powerbook G4 and when I went to restart it the display would not show anything. I can hear the startup sound but nothing on the screen....
Just remove ur CMOS battery and harddisk connection from motherboard. And then try to restart it will give u a msg no boot device or OS found.. Now reboot and add the CMOS battery and harddisk on motherboard...
Apr 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple spinning, won't start
1. Let it spin for a while and see if it eventually gets to the desktop. Sometimes this will work.
2. Insert your Mac OS install disk, restart your computer (if you need to force it to quit first, push and hold the power button until it shuts off). Then when you restart, as soon as you hear the famous mac chime, press and hold the C key until the Mac OS disk starts to load the system on the disk. Once it reaches the install window, don't launch the install, but go to the top menu bar and locate the Disk Utilities App and launch it. Run a Verify, Repair and also a Repair Permissions. Once done, shut down and restart without holding the C key. You should be good to go.
These powerbook 15" models are awesome... keep it hummin!
Dec 14, 2009 | Apple Powerbook G4 15" Screen Mac...
Mac Powerbook Charging Issue
If the magsafe is plugged in to the laptop and the wall outlet you should see a amber light on the plug. Once your laptop is charged the light will turn green.
Jul 17, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Won't Charge
Common fix for this problem is a simple Power Management Unit (PMU) reset. This will basically re-sync the battery "brain" to the computer so they when when to charge and when to stop. To do this, simply turn your computer off, remove battery and power cord and hold the power button down for 7-15 seconds. Then you MUST wait 15 seconds after pressing the button before applying power or inserting battery. 75% chance this will fix your problem. If Not, Replace Adapter/Charger. They have a microchip in them that can go bad that senses when to send more current to charge battery. Apple motherboards are generally better built so I'm not suspecting that at this moment. Let me know what you find out.
Jun 10, 2008 | Apple PowerBook G4 Mac Notebook
PowerBook g4 15" Screen Won't Display Anything!
your lcd probably just went out or the connecting cable just came loose(its in behind the lcd under the apple logo that lights up when you turn it on) if you open and close it frequently it will cause this
May 26, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple Powerbook G4 17in 1.33Ghz. Tiger OS. Airport problem.
I had a similar problem with my 15" 1.33GHz powerbook G4.
My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location.
it's underneath the battery pack.
1. power off your G4
2. remove battery pack
3. there is a latch on the right side (if the charger port is facing down), open it
4. pull back plastic cover tab and gently remove the antenna plug from the airport.
5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self.
6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook
7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch.
8. place battery back into your G4
9. plug computer in, turn on and it should work
if not then there is something wrong with the airport card reader, which i don't think it's the case here..
Jan 12, 2008 | Computers & Internet
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
400 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
