Question about Rockford Fosgate Car Audio & Video
Is the bass boost the gain or frequency knob?
  • 396 Answers
Bass boost simply adds DB or gain to the bass signal. Some like it, some dont.
The frequency knob is the Low Pass Filter (LPF) that cuts off the amp output above
the set frequency. A bass system usually cuts off below 400 HZ and more often 200HZ.
A good, rattle your car bass note is in the 25-80HZ range or lower but most amps and audio
input devices cant attain a good low note with clarity.
"Low-pass filter allows only frequencies below the crossover point to be amplified. A high-pass filter allows only frequencies above the crossover point to be amplified - useful for keeping low bass away from small speakers, so they can play more efficiently."
Checkout Crutchfields Glossary of Car Amps.
http://www.crutchfield.com/S-LPyoWWgD5qN/learn/learningcenter/car/amplifiers_glossary.html
Posted on Mar 15, 2011
Is my 1ohm 1 channel monoblock 4500 watts quantum amplifier to strong for my 3000 watts quantum subwoofers
If you are experiencing chirping or bottoming out the problem is you probably have your bass boost turned all the way up, your frequency responses probably turned all the way up, the speakers may not be able to handle that low of a Hertz, basically anytime you turn everything up on your amp you're going to get more and more disturbance this is most likely what you are hearing if you turn your bass boost down and turn your gain all the way down and the problem stops then this will be your solution, and it is an easy fix all you have to do is keep turning up your gain until you start noticing the Distortion then dial it back 10% you should never use bass boost on an amp it destroys the amp and definitely destroys the speakers
Jun 25, 2016 | Quantum Car Audio & Video
How do I tune my KICKER 08ZX1000? I have the amp running to alpine type r 12 inchs at 2 ohms but I don't know where the bass boost , gain, and crossover knobs should be pointing or what one to turn up...
To start, turn the gains on your amp all the way down. Bass boost should be off (this us used if you listen to your subs at low volume, the boost will heat your amp up quick if you use at high volume). Then turn the volume on your headunit up to 3/4 full. Make sure the filter on your amp is on low pass. The crossover point should be at it's lowest too. With all these in place, you can begin turning up the gain. You will have to decide at what point to move the crossover point. Since there are different styles of music, you will have to listen to where you feel notes are "dropping off" from the music. Adjust the crossover point to your liking, but remember that subs were made to reproduce low frequencies. Hope this helps
Aug 20, 2011 | Kicker Car Audio & Video
Volfenhag amp adjustments
Firstly, you will want to set all options to a low pass, so the high frequencies are filtered away from the subs, avoiding damaging the voice coil. Start with the Gain of the amp about 3/4 of the way up, and all other knobs, such as the bass knob to the lowest setting. From there, test your subs for soujnd, and then change the gain and amount of bass for the sound you desire, since each person is different. I have my gain about 1/2 way up and the bass about 1/4 of the way up. If you have a crossover knob, set it to the highest frequency available, since the low pass will filter all the high frequencies out anyway.
Sep 23, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
JL 13w7 & 1000/1 Settings
There is no "perfect" setting that can be placed in a manual. It's all done by ear. Your settings will vary depending on the vehicle you are in, the type of enclosure you have, the type of music you listen too, how much voltage your deck put's out. There are many variables, but I can try to give you a basic guide.
First of all you need to know your enclosure. If you have a ported enclosure tuned in the mid to low 30's you may want to set the low pass to around 70-80 hz with your sub sonic set at 30 hz. this will give you the higher bass frequency you need for the loud bass you want, and protect the sub from going too far below the tuned frequency of the enclosure, and losing it's composure.
As far as the gain, and bass boost are concerned, you just have to adjust them by ear. First adjust the radio volume to normal listening levels, by that I mean as loud as it can go without the speakers in the car sounding like ****. Now you adjust the gain first. slow turn the gain control, carefuly watching and listening to the sub.. Adjust the gain to the point of the woofer getting a lil sloppy then back it down a bit until the sound is clean again. Now do the same with the bass boost. if there is a bass boost frequency adjustment, set that as close to the tuned frequency of the box as you can.
If you are in a sealed box the adjustments are a bit easier, and are all about taste. Adjust the radio as described before, and put on your favorite song. Next start udjust thing lowpass frequency to taste, not too high tho, try not us higher than 100 hz in your sub's for better sound. Sub sonic is not quite as important in a sealed box, as there is much less danger of the sub losing control.
Well good luck, and hope this helps!
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
I have the Sony XS-L120B5D subwoofer with enclosure: sensitivity-89db RMS-600 watts Peak-2000 watts impedance-4 ohm frequency rangh-20hz-2000hz its hooked up to an Arc Audio ks 300.2 amp: class-g/h power...
Do you have the crossover switched to "low pass"? and the frequency control below 80hz? Do you have the manual? If you need more help, post a comment and I can walk you thru it. Hope this helps
Jun 24, 2009 | Sony XS-L120B5D Dual 12" Ported Enclosure
Amplifiers GT Series GT5-A604 ........explain settings
the amp probably has a x-over knob, a bass boost knob, and an eq knob. the eq is probably an internal crossover switch that will take the output from either high range (tweeters) or full range (6x9s) or low pass (subs) leave it on low pass. the bass boost however, will add distortion if turned up too high. its not noticable in the car, actually it sounds louder in the car but if you open the trunk and listen, you can tell its distorted bass and actually frying your speakers. the x-over knob is used to tune the frequency at which the amp stops pushing out bass tones. if you like rock music loud, turn it up higher, if you like low deep rap bass, turn it lower. keeping it too high might give you bad sound from either type though. ALSO THE GAIN OR LEVEL.IT IS NOT TO MAKE YOUR SUBS LOUDER IT WILL BLOW THEM .the gain is used to set your amp to your head unit which there is a procedure to do it.
Jun 15, 2009 | JBL GT5A604E 4-way Car Amplifier
Not gettin enough bass
Hello saini_jatt_2, On the JBL3501 700 watt monoblock, you have adjustments for low pass and a setting for boost marked DBO, allowing you to select and boost the frequencies sent to the subs. If your amp is not the 3501, but a different JBL amp, the settings may be different. Set the LP to either the white dot (about 100Hz) or slightly below to about 80Hz. Set the HP to about midscale or slightly higher. Set the boost to wherever the bass sounds best. One other setting that will affect bass volume is the "input level" or gain control. It should have been properly set by your installer, but you can "tweak" it for best performance. Turning it up increases the sensitivity and matches it with the output from your head unit. Too high will cause distortion. Too low will result in less bass. So you want to set it just to the point that you begin to hear the distortion and then back it off slightly until the distortion disappears. Hope this helps.
Jun 05, 2009 | JBL GTO1202D Car Subwoofer
Frequencies
Hello again ronnieyannon,
It's probably best to allow the amp that is powering the subs to control the frequencies going to the sub(s). I would not use the lpf on both the head unit and the amp in any case. The control settings are not completely precise and you could end up with a lot of tweaking between the units to get the sound you want. I'd send full range to the amp and with it playing something with a lot of bass, set the 401s to "LP", the crossover slope to near maximum, and then adjust the frequency until it sounded best to me. Starting on page 11 of your manual are the Rockford-Fosgate recommended adjustment procedures, including setting the gains and the filter frequency.
Those numbers for the lpf on your head unit sounds like it allows you to decrease (-24dB), as well as increase (+6dB) the bass at the specific frequencies of 50, 63, 80 and 100Hz. You probably don't want to decrease the bass boost for subs. And the 401s will allow a boost up to 12dB and is variable from 50-250Hz.
Hope this helps.
Apr 24, 2009 | Rockford Fosgate Punch 401S Car Audio...
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Bass boost/Gain
Both the bass boost and the gain generally do the same thing, except the bass boost is essentially "additional gain" at a particular frequency (in this case, 45Hz). I would suggest lowering the bass boost (10?) and adjust the gain. Honestly, you may have to play around with both settings until you find a happy medium. There is going to be a maximum the amp can provide no matter how you get there. Hope that helps!
Mar 03, 2008 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
314 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
