Question about Canon T90 35mm SLR Camera
Broken of the strap holder on the top of my T90 is it possible to repair
    Top Expert:
  • Canon Master
  • 14,162 Answers
Posted on Jul 18, 2016
3 Suggested Answers
  • 102366 Answers
SOURCE: canon t90 battery tray is broken
One source is here.
Posted on Apr 09, 2013
leorcid
  • 281 Answers
You will need to contact the local Canon service center.
Posted on Nov 22, 2013
I am interested in seeing the securing for my batteries under the bodywork
What make and model is it ,the battery on a bike is usually either dropped into a holder from the top with or without a battery strap to keep it still or sometimes they have a metal hinged strap which is bolted in.
Mar 08, 2015 | Motorcycles
Rear clunking noise when hit bumps
Could be
Exhaust pipe holder broken and pipe flopping when you hit a bump
Muffler too close to frame
Gas tank strap broken
Broken or shot shock absorber
Broken spring
With out being able see and hear it these are only suggestions.
Mar 02, 2015 | 2009 Pontiac G6
How to repair my broken wrist band
The local SEARS store has a watch-repair department.
May 19, 2014 | Sportline Solo 910M Heart Rate Watch
How do i attach carry strap
There is one tiny hole near the on "switch/button" on top and another below it on the side of the flashlight. Using a needle-nose plier, I was able to pry the round "metal" strap holder open and insert one end into the hole. If you're successful, you can just continue slipping the rest of the metal strap holder in and, lo and behold, you have attached your strap holder. No wonder they don't just attach it at the manufacturer - they'd probably have to add another $2.99 to the price because the attachment process is a PITA!
Jan 11, 2013 | Emerson 9X Power LED Flashlight
Have a dent in back panel. how do i get the inner panel off
Remove the handle and strap from the back lift door. The handle can be removed by using a screwdriver to gently prying the covers on the screws to access the screws. Once you remove the handle and straps, pull on the trim (inside) at the side of the back window. Don't worry it won't break. The clips might come off but you can put them back in later. Now you pull on the panel starting on the bottom and working your way around until the panel is free. You may breaker the clip holders but most of the clips will come off the door pretty easily. You may have to repair the clip holders if too many are broken. You will see what I mean. Do the reverse to reinstall.
Feb 06, 2011 | 2001 Toyota Sienna
My lcd is broken where can i find a cheap lcd replacement
Hello. As usual very few camera parts are cheap however I found an interesting offer on ebay.I have not delt with this seller and can't recommend them but it's a place to start. Here's the link.
builderdale
http://cgi.ebay.com/Sony-DSC-T90-OEM-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320474845959QQcmdZViewItemQQptZDigital_Camera_Accessories?hash=item4a9dca1307
Jan 26, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Need to repair wrist strap attachment on ixus 960
First things first, the small piece that holds the strap, when broken is repairable, but it is best that you dont since there is a strong possibility that the line will give up. the best options you may have to look for are camera pouches that are designed for the camera.
http://farm1.static.flickr.com/186/452068540_bf62b87687.jpg?v=0
http://ecx.images-amazon.com/images/I/51KXXHF3Q0L._SL500_AA280_.jpg
http://farm3.static.flickr.com/2117/2324527140_d133db348b.jpg
Jan 02, 2009 | Canon IXUS 960 IS Digital Camera
Canon T90
It kind of depends on what exactly the problem is. If the problem is that the speeds are off, then that can likely be remedied without any new parts. It needs a clean, lube and adjust. If its due to the shutter curtains being worn and they need replacing, then there is a possibility that it uses the same curtain as another Canon model and parts can be had new for that model. Worse comes to worse, a parts body can be used for the repair.
Watch the cost of this stuff though. T90s on the used market are selling pretty cheap, so it might make more sense to buy another used and keep yours for parts.
Dec 01, 2008 | Canon T90 35mm SLR Camera
Canon T90 35mm SLR Camera Logo
80 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
