Question about HP Computers & Internet
Hi, how can i change cooling fan speed on my hp dv6 pavilion 3125er? cooling system start fan when a temperature cpu 80/85 CELCIA, may i change this parameter? lake that fan will start on 40-50 CELCIA may be need ***.ini to change or i can download a program for coolfan but every programs i downloaded can view a temperature but can not change it.. my english very bad,sorry, thank you
No bios update where are fan control, riva tuner, fanspeed control, cpuid can not help too, support hp set a bot mashine with no recomendation, what to do? Wait whale my noute a burning up?
Posted on Mar 22, 2011
  • 66090 Mar 22, 2011
    in this utility no a fan control setting
  • 916 Answers
The fan control is a function of the bios and any override sttings would be available in the bios.
Posted on Mar 14, 2011
Hp pavavillion dv6 overheating issue
Following are the reasons for overheating, just take care of these things::
Stop Overclocking your CPU
Make sure your Heat Sink is placed properly above the processor
Clean the Processor fan, Heat Sink and other peripherals
Use High Speed fans
Use CPU Heat Sink Paste in the processor
Use Additional Cooling Units
Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher to maintain your system performance
Sep 15, 2013 | HP 417136-001 PAVILLION DV8000 MOTHERBOARD
Core temp
The fan could be partially faulty and cannot spin fast enough.
You can also purchase a fan assisted cooling pad and place the laptop on this cooling pad.
Apr 06, 2013 | HP Pavilion dv6-1030us Notebook
Can i adjust the fan speed in the bios on my hp zd8000
You don't have to reduce the FAN speed, because the Fan power works in PWM (Pulse Width Modulation). I.E if the CPU processing is increasing due to high process load, the fan speed changes accordingly to maintain a CPU normal temperature.
May 22, 2011 | HP Pavilion zd8000 Notebook
How to increase rpm of processor fan
There is no way to increase a CPU fan's rpm. But you can try changing the settings in the BIOS on how it work for your PC.
You will have two options, first is SMART Fan which automatically adjust your fan speed depending on the load and heat of the CPU. Second is Always ON, which, as the name implies, makes your fan constantly run on the top speed.
Hope this helps.
Apr 30, 2011 | HP Pavilion dv6000z Notebook
Hi. I have a HP laptop for about 3 months and now it gives me the message " a cooling factor is not working properly" , and it shuts down 15 minutes later. what should I do? Should I go to the...
The laptop should be covered since it is only three months old. That's the good news. The less than good news, is that you may have to wait a while before you get your computer back.
I don't have the laptop in front of me, so naturally I can't diagnose the problem directly.
I would hazard an intelligent guess that the Cooling Fan inside the laptop has failed.
Components inside a computer are normally cooled by air. (High tech gamer computers may use a different type of cooling system. They may use water, or a refrigerant of some sort. { Dry Ice, Nitrogen, Freon, etc)
Two main computer components generate the most heat.
The Processor, and the graphics chipset. (Video chip, Same/same)
The Processor is the 'Brain' of the computer. It's designed to operate up to a maximum temperature, (Thermal Limit), and no higher, or damage to the Processor will result.
There is a Fail Safe feature built-in to turn the Processor off, if it becomes too hot.
(BIOS turns the Processor off)
With no cooling fan operating the Processor will overheat.
You didn't indicate what model name, and model number your HP laptop is.
This is to just show you what an average cooling fan looks like in an HP laptop,
(HP DV6 series ), and what is entailed in order to access it,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/
Scrolling down to Step 24, and 25 shows the top view of the cooling fan.
Step 29 shows the bottom view.
Would appreciate hearing the outcome, please reply in a Comment.
Regards,
joecoolvette
Apr 26, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
I have an HP Pavilion a1730n. For the past 5 times I turned it on, I received an error message Error: The System Fan Has Failed!Service PC to prevent damage to the system.PressF2 to Continue I ran HW...
fan temperature and speed? Good question,. relevance is more towards the likelyhood that you've stored your pc on the floor and have dust/ debris which have gathered - a good cleaning of the fan may work, otherwise replacement is like 5 bucks... the can of spray air should be readily available at staples, unplug the power source and remove the cables, cover etc,. get into the unit and give it a good blast to see if that will suffice,. otherwise a cheap fan would do.
As far as the temperature of the processor which the fan cools - it goes to like 350 degrees as soon as it is powered up.. so it is best to be sure you have good airflow in and around the unit.
Best regards
Ck
Mar 14, 2011 | HP Pavilion a1730n PC Desktop
PC runs great until you power completely off. The it will take several tries of power on attempts. It will not start with the CPU fan coming on high speed. Must keep trying until low speed is heard. I...
Sounds like a problem with the power supply based on what you've written. Could be motherboard too, but Power Supply is usually the culprit.
I'd swap it out to test ;)
Jan 01, 2011 | HP Pavilion a450n PC Desktop
Hp pavilion a450n problem fan is running on high and keeps shutting down
First off - have you ever cleaned inside the case? You'd be very surprised how much dust often builds up inside a PC. After that it sounds like you might have another fan which has failed. PCs often have more than one inside and they also have temperature sensors to keep the CPU cool. If a case fan has failed it would not have air flowing inside to cool off the other components and then the CPU sensor would kick the processor fan into "overdrive". One thing to note; the difference between a two wire fan and a three wire fan is that the third wire is used to confirm the speed of the fan. Fans are usually easy to replace - just get the right size and the same right plug.
Apr 21, 2010 | HP Pavilion a450n PC Desktop
No fan of three fans!
YOu can use software like CPUcool to monitor and manage your system. It uses temperature sensors (if available in your laptop) to measure temperatures, and has features to manage CPU speed and some more.
May 21, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion Laptop
ya change that heat sink out get new thermal paste on cpu screw down mobo and everting else tight ok newegg.com sells fans for heatsinks just gotta figureout what soket uuse ok
Jan 30, 2008 | HP Pavilion (F2111-60950) CPU Heatsink &...
Computers & Internet Logo
1,021 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
