Question about LG WM-2277HW Front Load Washer
LE message and appears drum does not turn - LG WM-2277HW Front Load Washer
  • LG Master
  • 1,902 Answers
Hello & Welcome to FixYa
LE error code in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Posted on Mar 14, 2011
2 Suggested Answers
  • 389 Answers
SOURCE: LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Posted on Nov 28, 2011
LE LIGHT IS APPEAR
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 12, 2012 | Washing Machines
Nov 28, 2011 | LG WM-2277HW Front Load Washer
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
LG WASHER WM0532HW, ERROR MESSAGE LE WATER INTAKE ERROR
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | LG Washing Machines
How do you replace a lg drain pump for model WM2277H? Washer shows error message LE and will not drain
Hi
Daniel
Aug 06, 2011 | Washing Machines
My machine keeps an error message le how do i fix it
Hi
Daniel
Nov 26, 2010 | LG WM2688HWM TROMM SteamWasher
Washine machine MF81061 showing error message LE after switched on
Hi
Error code LE indicates that eirther the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure its not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Sep 01, 2010 | Washing Machines
I purchased a used LGWM1814CW washer Thursday 028/26/10. The seller delivered it to me. When I attempted to wash a load, the washer filled with water but the drum ould not turn (agitate). It tries to...
most likely a defective motor hall sensor. it's attached to the inside of motor stator. part is approx $30. it's not easy to replace if you do not have the tools.
Aug 29, 2010 | LG WM1814CW Front Load Washer
Spinning Motor is overloading
Hi
Thanks for using FixYa. LE error is a communication error between the control board and the motor. In you LG washer the Hall Effect sensor board monitors the direction and speed of the motor and sends this information to the control board. Usually the issue is with this Hall Effect sensor going bad and should be replaced. However, to make sure it’s not a locked motor, try turning the drum with your hand. And, if you feel some resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If it is fine then it is the Sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | LG WM-2277HW Front Load Washer
Error message LE
1. drain water
2. unplug for 20 minutes
3. spin the drum manually 3 rotations
4. back in business
look at this link below it has "Other" info
http://www.howtomendit.com/answers.php?id=28214
Mar 06, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG WM-2277HW Front Load Washer Logo
342 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
