Question about Acer AL2216W LCD Monitor
I Have an ACER AL2216W LCD Monitor. Problem Screen comes on than seconds later cuts off. I get the green LED than it goes back to yellow or some times stays green but goes black screen
  • 11,361 Answers
Does it do the same whan attached to another PC? Cables are good?
If it is monitor, you will need to check the caps and DC voltages first.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL2216W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 15, 2011
I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
Dec 22, 2011 | Acer AL2216W LCD Monitor
I have acer lcd al2216w on the lcd there is a green line comes between my screen it cant be remove i dont not how he comes please tel me what i do change a new lcd or what it can repairable or not
Hi there reinstall the display driver & then give a look. If you face same problem then its may problem with your display driver or in the monitor.
Jan 18, 2011 | Acer AL2216W LCD Monitor
The monitor is on for 1 second then screen goes black
kippi09, You will just have to learn how to do visual inspection/possible cheap repair to units internal switch-mode-power-supply/inverter board if warranty with ACER not valid any more. Do you understand "flashlight-test" to evaluate SMPS status? 12fixlouie northwest of Windy City.
Sep 12, 2010 | Acer AL2216W LCD Monitor
Acer AL2216W's green light goes off completely when the computer is turned on. When I turn on the computer and monitor, there is green light on on/off button while an irritating Acer logo is showing up....
You may have failure in the power supply due to bad caps, bad inverter circuits such as shorted transistors, transformers, bad lamps. You need to open it up and make some measurement, see example of failed ACER monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 13, 2010 | Acer AL2216W LCD Monitor
Trying to find out if this ACER monitor is under warranty
Your monitor is still under the 3-year warranty. Go to this Acer website https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
to begin the process. Hope this helps.
Jul 09, 2009 | Acer AL2216WBD LCD Monitor
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Monitor light: green yellow green yellow etc.
Cycling of the power LED (about once per second) is typical of a switchmode PSU shutting down and trying to restart. Often this is accompanied by a tick each time, from the main switcher transformer.
Assuming you can open the monitor up (with the power OFF of course) check all the capacitors in the PSU for signs of leakage or bulging. Ideally you would check them with an ESR meter, but they are usually visibly failed when the monitor acts like this.
Replace any defective caps found and try it again while you have the case off, keeping your fingers well out of the way.
May 07, 2009 | HP L1706 17" LCD Monitor
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Acer AL2216W LCD Monitor Logo
175 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
