Question about Fisher Dryers
It is noisy sounds like belt slipping as it squeaks
  • Fisher Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Mar 15, 2011
When I turn my steering wheel on my 2001 Camry hard right or left it makes a squeaking sound, why?
The belt is slipping that drives the pump as the pump is pressure locking at the stops and the squeal is the belt slipping on the pump pulley
Apr 18, 2017 | Cars & Trucks
Squeaking sounds
slipping belt drive on drum , have it checked.
Mar 22, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
Squeaky noises under the hood
IT COULD BE AN IDLER, TENSIONER, OR THE BELT SLIPPING, THESE ARE SEALED YOU CAN'T LUBE THEM. IT SOUNDS LIKE THE BELT IS SLIPPING, BUT IT COULD BE SLIPPING BECAUSE OF A FAULTY IDLER\TENSIONER. REMOVE THE BELT, MAKE SURE ENGINE IS SHUT OFF, AND YOU HAVE THE KEYS, ROTATE ALL THE PULLEY'S AND THE ALTERNATOR PULLEY THEY SHOULD ROTATE FREELY AND RUN TRUE, AND NO ROUGH FEEL TO THEM, OR THE TENSION COULD BE TOO WEEK TO KEEP THE BELT TIGHT.
Jun 09, 2013 | 1996 Oldsmobile Bravada
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
I have a squeaking sound that I think is coming from the ac compressor. I noticed it stoped when I put on belt dressing and the pulley got wet. I heard the same sound coming from other monteros as well,...
once the belt become loose it slips and its friction surfaces become damaged .. even if its then tightened properly it may still slip .. an old damaged belt should be replaced and tensioned properly ... its common for older type belts to slip and make noise .. it is not as common in later cars since they often have automatic belt tension and improved belts .. any slipping is a sign of some other problem ... one frequently seen problem on some cars is a pulley that is spring loaded to keep the belt properly tightened .. the pivot on the pulley freezes up and no longer maintains proper tension .. those pulleys can sometimes be re lubed but often are hopelessly frozen and need replaced ... also other pulleys and the alternator bearings can start to make a squeaking noise when the sealed bearings lose there lube .. you can put a drop of oil on each bearing to see if one quiets the sound ..
Sep 17, 2010 | 2001 Mitsubishi Montero Sport 4WD
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Lg front loader makes squeaking sound and struggles to spin
The drum is powered by a small motor and pulley, inside the unit and under the drum. A large belt wraps around the drum and pulley, and a spring "thing" provides tension so that the belt won't slip. The squeaking sound indicates that something is slipping, and the sluggish drum says that it's the drive belt. Take off the back, locate the motor/pulley/spring thing, and check the belt tension by observing the belt with unit operating. At that point you should easily locate the noise, at the motor (noisy bearing, lube or replace), belt warn (replace) or possibly the felt pads located at the top of the drum worn (not as likely but they do fail causing the drum to resist being spun by the motor to the point that the belt starts to slip. Hope this helps!
Jan 08, 2010 | LG WM1812C Front Load Washer
93 Accord belt squeak at start up
worn pulley on the crankshaft will cause belt to squeak.pulley has worn to a point where it become to smooth belt cant grip it while turning so it start slipping making squeaking sound.
May 25, 2009 | 1991 Honda Accord
Dryers Logo
49 people viewed this question
Top Fisher Dryers Experts
Tim Whalen
paul
paul
Tom Chichester
Are you a Fisher Dryer Expert? Answer questions, earn points and help others
