Question about Trident BLADE T64, (32 MB) PCI Graphic Card
Trident graphics card
I have a pentium 3 pc which its embedded graphics port is comprimised therefore I use a graphics card. The problem however is that the graphics are poor and i can't change the screen resolution and colour depth from 4bit to 32bit and the resolution from 480 by 680pixels to 800 by 600.Are there any drivers available to update my graphics card as it was used on a pentium 2 pc
  • Try installing the driver of the video card.
    it is usually a driver issue if the resolution can't be changed.
  • 781 Answers
Your graphics card need drivers as you computer is only running on basic video what is the card name and number please
Posted on Aug 02, 2008
Required Intel SL9CB Pentium, 3 GHz compatible motherboard
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Pentium 4 HT, Model 531. sSpec number SL9CB.
OK. So far I know you need a motherboard that has an LGA 775 processor socket; needs to support Intel processors that are Single-Core, and with an 800MegaHertz Front Side Bus.
(800MHz FSB)
Ram Memory? Dunno. K
Do know the rule of thumb is, that the Ram Memory typically operates at Half of the processor's FSB.
Therefore can only assume the ram memory is DDR Sdram, and operates at 400MHz. (PC-3200)
You haven't stated the motherboard chipset that was used, OR what computer manufacturer, and model number; this mobo came out of.
(MOtherBOard)
Also didn't state if you are using a graphics card, and what kind it is.
(PCI, AGP, or PCI Express)
This isn't a 'guess-ti-mate'. Exact specifications are required in order to replace the motherboard.
Otherwise you may not be able to reuse the Ram Memory, or graphics card. (IF used)
Awaiting needed information. Post back in a Comment.
Regards,
joecoolvette
Oct 30, 2012 | Intel SL9CB Pentium, 3 GHz
My mother board cd is not supported my mercury motherborat as i have no listen to music pls help me.
From the motherboard type given, below are the technical specifications:
  • General Features:
  • VIA P4M800/VT8237R chipset
  • Socket 775
  • mATX form factor
  • Version 1.0
  • Supports up to 2 GB 2.5V DDR SDRAMs (DDR400/333/266)
  • Embedded UniChrome Graphics with 64 MB shared memory
  • Realtek ALC655 6-channel Audio Codec
  • Compliant with AC'97 2.3 specifications
  • VIA VT6103L 10/100 Mbps Fast Ethernet PHY
  • Two (2) SATA/150 (Serial ATA) connectors
  • Two (2) UDMA/133/100/66 IDE controllers
  • One (1) Floppy controller
  • Expansion Slots:
  • One (1) AGP Ultra slot
  • One (1) CNR slot
  • Three (3) PCI slots
  • Two (2) 184-pin DIMM sockets
  • I/O Ports:
  • Two (2) PS/2 ports
  • One (1) 9-pin Serial port
  • One (1) 15-pin VGA port
  • ONe (1) 25-pin Parallel port
  • Four (4) USB 2.0 rear ports
  • Two (2) USB 2.0 ports via header
  • One (1) RJ-45 Ethernet port
  • Line-in, line-out and microphone jacks
  • BIOS Features:
  • AMI 4Mb Flash ROM
  • Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
  • Full support for ACPI revision 1.0 specification
  • Supported Processors:
  • Intel Pentium 4 and Celeron D processors with Hyper-Threading Technology
  • Socket 775
  • 800/533 MHz FSB (Front Side Bus)
  • Regulatory Approvals:
  • FCC
  • CE
  • C-Tick
Package Includes:
  • Mercury P4VM800M7 VIA K8M800 Socket 775 mATX Motherboard
  • Manual
  • Driver CD
  • SATA cable
  • IDE cable
  • Floppy cable
  • SATA to 4-pin power cable
  • I/O shield
You will therefore need drivers for the following devices to utilize the multimedia functions of your system:
Download the Realtek ALC655 AC97 Audio Drivers from here(Link:http://download.cnet.com/Audio-Realtek-ALC655-AC-97-AUDIO/3000-2110_4-168843.html?tag=contentMain;overviewHead) and the Embedded UniChrome Graphics drivers from here(Link:http://download.cnet.com/VIA-S3G-UniChrome-Pro-IGP/3000-2108_4-65294.html).
Have a good time ahead.
Feb 03, 2011 | Mercury P4VM800M7 Motherboard
I cont play 3d games graphic card is there in acer aspire 4720z
* The system configuration of Acer Aspire 4720Z PC Notebook is :
160 GB or larger hard disk drive / 5-in-1 card reader / 512 MB or 1GB DDR2 533 MHz DIMM module / Intel Pentium dual-core mobile processor technology T2310 (1 MB L2 cache, 1.46, 533 MHz FSB), Mobile Intel GL960 Express Graphics Chipset.
* Your system have "Mobile Intel GL960 Express Graphics Chipset" graphics accelerator card embedded in the motherboard. Like most of the laptops/notebooks, there is no room for upgrading the graphics card in the motherboard!
* But you can upgrade the RAM upto 2 GB using two DDR2 DIMM memory modules.
* If you want to play 3D games with better performance, switch to Windows XP SP2 and upgrade the RAM!
* If you want to upgrade the memory (RAM), you can check this site : http://www.laptoppartsexpert.com/c-60093-acer-aspire-4720-series-as4720z.html
please rate this advice if it helps
Nov 17, 2010 | Acer Aspire 4720 Notebook
I want to buy a laptop. Please suggest me which processor is best? ie. Intel pentium processor or intel pentium dual core processor? Will intel pentium dual core processor overheat easily?
hello,,,,,,,,,,,,,
First you need to be clear that dual core is the family of Pentium series. so there is no processor called Pentium.............. now regarding your question i would suggest you do not go for dual core... Take core 2 duo or I3 /I5/I7 series of processor..............
I am giving you a configuration in a good budget
Rs 50,800/-
Intel 3 GHZ Core2 Duo Processor,3 GB DDR2/DDR3 RAM, and a 250/320/500 GB HDD. DVD writer, 15.4-inch display with a resolution of 1280 x 800 dpi. integrated Intel Graphics Media Accelerator X3100 video card, integrated modem and sound card, Wifi, Touchpad mouse and in-built speakers. It has interfaces like Express Card slot, S-Video port, 4 USB ports, Firewire port, bluetooth and a 6 in 1 Digital Media Reader. The laptop comes with an inbuilt camera .
It would be better if you can tell me your budget ............... So that i can give you a good configuration ......................
Jun 14, 2010 | Computers & Internet
How do I find my graphics card on acer laptop 4720z and change settings to best play games
please rate this advice if it helps...tc! :)
Jan 13, 2010 | Acer Aspire 4720 Notebook
Can some one please let me know the name of the motherboard supporting Pentium 4 1.5 Ghz processor as well as Intel Core duo series of processors. Thanks, Ajay
The chips to which you refer are incompatible with respect to the socket used for each as well as the fact that Core duo and Pentium 4 1.5 GHz chips are from separate generations, the latter having been obsolescent since 2003. Therefore, there is no single motherboard that supports both, and the Pentium 4, Socket 478 boards can be obtained from various aftermarket sources.
Here is an example of the kind of board you need for your Pentium 4.
$11 to $290 from 21 sellers
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 3 reviews
ATA-100, Serial ATA-150, 0 MB / 4 GB (max), DDR SDRAM, Intel 865G, 4 x USB
Prepare for the future with the Intel Desktop Board D865GBF, a platform that is truly a generation ahead. This ATX board features next-generation processor, dual-channel DDR400 memory support, integrated Intel Extreme Graphics 2, an AGP 8X slot, 8 USB 2.0 ports, integrated 6-channel audio and next-generation storage device support.
FEATURES AND BENEFITS
Support for the Intel Pentium 4 processors featuring Hyper-Threading Technology and 800-MHz system bus in the mPGA478-pin package. Also supports the Intel Pentium 4 processors (1.60a, 1.80a, 2a, 2.20 GHz or higher) with 533-MHz or 400-MHz system bus in the mPGA478 package.
Intel 865G Chipset featuring Intel Extreme Graphics 2 using Dynamic Video Memory Technology (DVMT). Low-cost, high-performance graphics solution.
Dual-Channel DDR400 SDRAM support: Four DIMM sockets designed to support up to 4 GB of DDR400 SDRAM memory (also supports DDR333 and DDR266). Flexible support for either single- or dual-channel operation.
AGP 8X/4X graphics interface: Flexibility to upgrade via a high-end AGP graphics card.
SATA150 and Ultra ATA100 connectors: Flexible support of new-generation SATA150 (2 ports) and current generation ATA (2 channels) storage devices. « less
While the board for your Core Duo is widely available now
Mar 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Trident 32 chaintech
http://www.driverskit.com/freedownload/Video_Card/Trident/Blade_3D/11344.html
try the above site
or this site it lists more drivers
http://www.opendrivers.com/categorycompany/12/11638/display-and-video-trident-free-driver-download.html
Aug 05, 2008 | Trident BLADE T64, (32 MB) PCI Graphic...
Trident BLADE T64, (32 MB) PCI Graphic Card Logo
190 people viewed this question
Top Trident Computers & Internet Experts
David
David
waruna
NOEL
NOEL
Are you a Trident Computer and Internet Expert? Answer questions, earn points and help others
