Question about Kitchen Ranges
I have a Nordic Track E 2900 treadmill and when I plug it in I have a solid red led light on the computer board but nothing on the console even with key in.
  • biehldm Mar 15, 2011
    No that is no a fix.I have already been in contact with others that said that it was the motor controller board that also supplys power to the console.Your answer is not even close to a repair.This is the second time I have used this service and got no help what so ever with problem.I expect a full refund and I will never use this service again.
  • Kitchen Ranges Master
  • 12,061 Answers
Http://www.nordictrack.com/webapp/wcs/stores/servlet/Help_-1_10301_12401
above is your support site.Below is the web site so you can contact them.
http://www.nordictrack.com/webapp/wcs/stores/servlet/FAQ_-1_10301_12401
Hi, this seems to be some sort of fault, that has caused the unit to shutdown, most likely some component is about to fail, catastrophically, this has been "Sensed" and the Computer has "Shut the system down" to avoid a fire an explosion or perhaps both. It may be a power supply problem itself, or some other problem overloading the power supply.
The fact you have an illuminated LED means that power is actually entering the unit, however IF there is NO display etc, than this indeed indicates a potentially serious problem.that needs to be addressed by a professional, familiar with this type of device.
My professional advise is to contact the manufacturer and explain things to them and ask them "What to do" and be guided by them, they have the know how and capability better than anyone else to appraise and remedy your problem, faster and less expensive than any other way.
Posted on Mar 14, 2011
I have a Nordic Track C2155 that doesn't power up on the display after inserting key. The red LED on the power supply board does light up
The circuit board is fried. It's too expensive to have fixed if the warranty is expired. You can try and find a used display from ebay or craigslist. It would be an easy swap.
Jan 01, 2017 | Nordic Track Exercise & Fitness
Console does not work it lights up but no buttons function
this just happen to mine this morning, can't find a fix. Help!
Mar 17, 2014 | Nordic Track Nordictrack Exp 1000...
Nordic track commercial 1500 no power
looks like there is power to the board. the board the sends power to the console. there could be a loose connection at the board
Mar 04, 2014 | Nordic Track NordicTrack Commercial 1500...
Fuse looks ok red light lit even without fuse no power to consol
1)Replace the batteries with full charges, with the same mark, do not mix another. with the same polarity
2) Clean the contacts cleaners very well
3) TIGHT THE spring contacts with long pliers for better contacts.
4) Adjust the REED swtich see the diagram, test for open or faulty, clean it, and tigh the connector very well.
5) TGITH the ribbon cables inside for keypds and tight lower connecer display vs lower board connector.
God bless you
Dec 13, 2012 | Nordic Track Nordictrack A2350 Treadmill...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
I have a Nordic Track Commercial 1500. When I plug in everything comes on find but it will not start. The belt does not move even with no one standing on it.
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Aug 14, 2010 | Nordic Track NordicTrack Commercial 1500...
Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Ifit Treadmill has power but walking pad not working
Apr 18, 2009 | Nordic Track NordicTrack Treadmill, A2550
Need to put together a Nordic Track Elite 2900 treadmill.
go to the nordic track website, you can download a blow up of the treadmill that shows how where everything goes, you can also download any manuals you may need in pdf.
Mar 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
