Question about Home
Triton ivory 2 shower water is very hot even on lowest setting any suggestions?
    President:
  • 3,433 Answers
Hi, You possibly have a defective thermostat. Have the unit checked by someone who is qualified on you type of unit. Good Luck --Ned
Posted on Mar 14, 2011
Triton cara shower has power and water to it but nothing comes out
CHECK YOUR POWER SUPPLY BOX MAKE CERTAIN THAT IT IS INDEED ON IF SO IT MAY BE A BAD CIRCUIT BRAKER MAY NEED TO REPLACE IT.
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
Unpredictable water temperatures!
i am not an expert but i have a hunch it could be the tempeture gauge but i have no solution sory
Jun 19, 2012 | Home
Triton Ivory 2, 8.5 kw electric shower flow has been getting porgressively weaker. Mains pressure if fine. Shower head is clean.
there could be a blockage on cold water connection which may have a filter which needs cleaning or the heating tank inside the shower could be blocked with limescale try cleaning the filter you cvould also check the shower hose for blockages or kinks
Dec 09, 2010 | Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
Triton ivory 2 drips from shower hose when switched off any ideas or does it all need replacing thanks
heat from my shower keeps changing temperature, it will not hold the same temperature for very long...any tips ?
Mar 20, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
Our shower does not have hot water coming out from triton ivory 2,plse advise the part i need and how much will it cost
Thankyou,
Bonjouir Mosuir,
Pardon me, V, would like to render a little idea insight on this. :)
I would take a look at the induction plate, (this is ususally the heating element where water is channeld through), if it reads current through it fine. Then relate to the components, fuse etc and refer then to manual and try to replace any part. My guess the pump system is flawless, the contrary is definitley the heating element. Try to replace it and WaLa...:)
Thankyou, :)
me, me, V
Jun 30, 2009 | Home
I have a triton ivory II shower, when the shower is switched off water continues to flow
Replace all or just your shower handle seat and washer on the shut off. Seems like a seal has gone bad and is not letting anything seat properly
Apr 18, 2009 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
199 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
