Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Installing waste ctg #4049111
I have a client that bought a waste ctg #4049111 for Konica C351...
How does she install it?
She doesn;t have owner's manual...
  • 148 Answers
If you go to this web page:
http://kmbs.konicaminolta.us/productsattachments/manuals/opsc350.pdf
You will find the operation manual for that machine.
The c350 is the same as the c351
Hope that helps...
Lbcoaster
Posted on Aug 01, 2008
C 3201 bizhub c351
did you reset the machine after installing the different fuser a different fuser does not reset the machine requires a manual reset procedure your old one might be ok just got to hot and shut down reset the machine.
Apr 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
I can't install my c351 on windows 7 64 bit
The latest 64-bit printer drivers are available via the Konica Minolta Download Selector. Access the Selector from the KMBS public site (http://www.kmbs.konicaminolta.us) Support & Drivers tab or from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'
Jan 29, 2011 | Konica Minolta bizhub C351 All-In-One...
I have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
May 15, 2010 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta C351: stop Banner Mode?
this problem can be remove by upgrading its firmware. ask your technician to upgrade the firmware of the machine.dont replace the board. try this.
Apr 02, 2010 | Konica Minolta bizhub C351 All-In-One...
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
Mar 29, 2010 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Aug 05, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
Bizhub C351 Magenta Image Unit Problem
The C531 uses 4 toner cartridges and 4 corresponding imaging units. Each imaging unit has a waste compartment for the residue toner not transferred to the Image Transfer Belt (the waste bottle is for waste from this ITB). The residue toner could be reused.
It does not sound right that after 3-4K pages you have to change the IU. Just to be sure the IU you replaced looks like this?
ef6970d.jpg.
Each IU should last about 50K pages (ie to be replaced after 5 toner cartridges).
Jan 14, 2009 | Konica Minolta bizhub C351 All-In-One...
Desktop faxing from Konica c351
Go to this link to get the fax drivers you need.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=827&filetypeid=0&osid=3
You should have had a cd that came with the machine that has them as well. Once they are installed, go into Microsoft Word and select the fax to print from. A screen should appear asking you for the phone number of the name out of the address book.
Sep 26, 2008 | Konica Minolta bizhub C351 All-In-One...
I cant install konica Minolta bizhub C351 on my mac. please HELP
To print via IP on MAC  type IP address in queue type print ,name the printer and  the correct driver/ fy...35/
Mar 13, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
73 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
