Question about Cerwin Vega CLSC-12S Subwoofer
After turning on, even at low listening levels power indicator light goes from green to red and sub shuts down after about 10mins.
    Brigadier General:
  • 8,546 Answers
Perhaps its amp is overheating.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 14, 2011
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
When i start my camera it turns the light green to red and shuts off immeditaly
Green light indicates good battery strength. Red light indicates that your camera has an insufficient or low battery power level and will be automatically powered off. . To continue using the camera, please change your batteries to new ones.
Please note that:
  1. If you don’t intend to use your camera for an extended period of time, please remove the batteries to avoid battery leakage and corrosion.
  2. Do not mix old and new batteries.
  3. Alkaline batteries are generally recommended.
Feb 13, 2010 | Vivitar ViviCam 5355 Digital Camera
I was playing and my system shut off. the indicator light was blinking red. i hit the power button once and the indicator light went back to a solid red light. i tried turning the system back on and the...
You need to have the motherboard fixed, do to so you need to take the PS3 apart then reflow the board.
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video about 10mins long, goes over everything for you.
http://www.youtube.com/user/gilksy1 and its free unlike some eBook site.
I actually used the videos shown by this guy to fix about 30 PS3 units with no problems, you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Kenwood kac-7202
Nope it's not a high-to-low level converter problem, it's most likely a problem with one of two things. 1) either you've blown the output stage in the amplifier, or 2) you've hooked up your subs wrong and your amp is seeing to low of an impedance. The amp is supposed to be 1ohm stable, but we had the same problem. When the indicator light goes red it means that the amp has gone into protection mode, now you have to figure out why. If something in the amp goes bad or just disconnects from the board it will cause power protection mode. If you fry something on the board because you are running the amp to hard or at the wrong impedance it will go into thermal protection mode, however there's no simple way to figure out which has happened.
Have you tried hooking up some different subs to see if the problem remains? try this. If the problem no longer happens then you know it's your subs, if it does still happen then you'll know it's an internal problem.
Years ago I had a Kenwood KAC-821; long story short, I melted the main power wire right off of the board, everytime I turned the system up the amp would shut down.
Take you amp to an authorized dealer and have them bench test it for you.
Let me know what you find out.
Jul 14, 2008 | Kenwood KAC-7202 Car Audio Amplifier
500.1 amp power lights blinks on and off
Protection mode; follow this link to get a manual for the amplifier: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Below information is from the manual:
Status Indicator Lights / Protection Circuitry
There are three status indicator lights on the top of the amplifier. These are as follows:1) "Power" (Green): lights to indicate that the amplifier is turned on and operating normally.
2) "Thermal" (Red): lights to indicate that the amplifier has exceeded its safe operating temperature, putting the amplifier into a self-protection mode, which reduces the power output of the amplifier. The red light will shut off and the amplifier will return to normal, full-power operating mode if the heat sink temperature drops back to a safe level.
3) "Low ω" (Amber): lights to indicate that the impedance of the speaker load connected to the amplifier is lower than the optimum impedance load range for the amplifier. When this light is on, a protection circuit engages and reduces the power output of the amplifier. The amber indicator will also light when a short-circuit is detected in the speaker wiring (this can be a short between the positive and negative speaker wires or between either speaker wire and the vehicle chassis).
There is only one condition that will shut down an undamaged 500/1v2 completely… If battery voltage drops below 10 volts, the entire amplifier will shut itself off. The green "Power" indicator on the top of the amplifier will turn off when this occurs. The amplifier will turn back on when voltage climbs back above 10 volts. This may happen in a rapid cycle when bass-heavy program material causes a weak charging system to dip below 10 volts momentarily. If this is happening in your system, have your charging system inspected to make sure it is working properly.
For information on troubleshooting this amplifier, refer to Appendix E (page 21).
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
Apr 12, 2008 | Audio Players & Recorders
Shuts off after playing music
i had the same problem, apperantly creative made an error making the hardware for the subwoofer, and put in an mos-fet with to little resistance, i called creative and gave them the serial number behind the subwoofer and they sent me a new one that hasnt acted up yet.
Jan 13, 2008 | Creative Labs Gigaworks S750 Computer...
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Cerwin Vega CLSC-12S Subwoofer Logo
326 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
