Question about Whirlpool Washing Machines
My whirlpool duet washer (only had it for 6 months)makes a loud humming which i assume is coming from the drain pump while spinning. I have checked and cleared the drain filter behind the kick plate. What i would like to know is what else can I do,or how can I check further up in the drain .The drain filter is clean,and it still empties out the water.But boy is it loud.
  • mark1957710 Mar 23, 2011
    Yeah, I removed them when it was delivered.Just had third service call. First one said I was using too much soap, so we cleansed the washer with vinegar,and use one tbs of 3x soap per wash,second said it was everything from the bearings spinning the drum,to the accoustics of our house...I just about tossed the guy out. The last one said it was the pipe that runs from the pump to the drain vibrating against the plate. So he fooled around with it, ran one of his diagnistics, and it sounded better. I figured out later that he ran the spin without water,so the drain didn't make noise. So,it still makes noise. I ran the spin cycle,while the noise was going on,I unpluged the power to the pump.I'm 99% sure the pump is the source of the noise. I just don't know if a new pump is the answer,or is the poroduct just garbage.
  • 33 Answers
Have you removed the shipping bolts when you got it? It would be 4 big silver bolts in the back of it. Otherwise you are still under manufacturer's warranty so a service call will be free.
Posted on Mar 14, 2011
Whirlpool front load washer model WFW9050XW00 - Machine stopped still loaded and with door locked. I was able to unlock and remove clothes leaving water and heavy suds. Tried running drain-spin and...
Your pump is jammed with a blockage, remove the filter and check the pump behind it is revolving, usually a hair grip or button in there...remember the washer is full of water so you will have a lot of water coming out
Sep 05, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine isnt' draining nor spinning.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet makes loud noises(Hummm) during spin ( drain) cycle. Any idea what would cause that? Unit seems to function properly. Could it be out of balance?
You will need to clean the catch out that is located in front of the pump. Sounds just like it is full of lint or has something clogging it restricting the water from draining. This is where the humming comes from. If you take the bottom panel off. You can see the catch. Just open and clean out.
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Whirlpool LA6800XTWO will not drain or spin
Need a new drain pump. I just had this problem. found a drain pump on ebay for 60. Replaced and running mint again. don't keep trying or you will burn out your motor.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
