Question about Kenmore Washing Machines
The washing machine is leaking water on the floor from under the machine.
  • 5,911 Answers
A leaking washer can have several causes. In order to be able to accurately determine where the leak may be coming from, you will need to remove the exterior washer case to get a full view of all the interior washer components. The following link explains how to perform this procedure and what to inspect for:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
From the symptoms you have described, it sounds like you may have a leaking drain pump. These pumps are not serviceable, and if leaking, they must be replaced. The following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The average price for a pump is about $35.
NOTE: Kenmore washers are manufactured by Whirlpool, so these instructions do apply.
NOTE: If this is a FRONT loading Kenmore, the following link will give you some guidance on how to inspect for leaks and what to look for: http://www.fixya.com/support/r3576656-washer_leak__front_loader If you have any questions about any of these procedures, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Mar 14, 2011
Replaced washer door seal but still leaking from beneath
need more info how much water do you see ie one or two cups off water on the floor and when do you see it ie as you switch machine on or how long into the wash program
Dec 12, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
I have a Whirlpool washer, i put a new water pump on and i put a new drain hose on. And it's still leaking water on the floor what could be wrong.
on this machine common problem is look right under the machine right under the heater you will see its coming from there if its not from there it will have a split in the drum as the plastic is really fin have a good look you can arrowdite normaly will do the trick but make sore all water is gone ok
Oct 18, 2012 | Whirlpool Washing Machines
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Washing machine is leaking water from some where under the machine external hose ok.
the washer is leaking on the floor last time a bobby pin was stuck in the flop how do you check the flap to see
Sep 19, 2010 | GE WDSR2080D Top Load Washer
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Water on floor when running, but hoses aren't leaking
never fear i to had this problem and by simply closing the door the water doesnt go on the floor. happy washing mr fixit.
Apr 26, 2009 | Washing Machines
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
44 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
