My oce 4780 scanner has a problem, it warms up ok then I scan a couple of maps then the maintenance and clock light come on. If I turn off and on it will eventually go away, but the help on the oce scanner program says b camera cant adjust.
  • Computers & ... Master
  • 27,725 Answers
The drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Posted on Mar 14, 2011
I recently purchased a Uniden bc345crs scanner. I programed 5 codes, but it will only scan one of the codes continuously. What do I need to do to have it scan the other programs? Thanks
Make sure you do have frequencys stored. Turn it on, push button to clock, then press bitton to scanner, then press hold, then the channel # you want it in, press hold again, now press e, enter frequency, press e again, if you want more channels press up, press e. Do this until channels are full or what you want. Then press scan if radio is ok it should scan.
Jan 24, 2015 | Uniden Radio Communications
Oce tcs500 scanner - error code 10514-246 scan failed. any solution for fix?
Repair of oce scanner with error code 10514-246:
The customer Service said that this error means there is not enough light reaching the camera and we have to let them replace the lamps. cost:1500€ :(
solution: i removed the backplate of the scanner (3 screws) and cleaned the lower mirror. it was that dirty that i nearly didnt find it. it is placed on the groud of the lower big hole behind the backplate.
After that i recalibrated the scanner and now it works fine again.
I hope this helps since there is no correct exlanation of this error on the web.
Nov 01, 2013 | Office Equipment & Supplies
My Oce Scanner has the 10514-246 error. Please help me !
my oce tcs500 error code 10514-246 start of scan failed
Sep 07, 2011 | Office Equipment & Supplies
I need an Operator's Manual for the OCE CS 4035 scanner.
Google it, they have it. I found the manual for the Oce' copier so I could check out the scanning mode. Hope this helps.
Mar 18, 2011 | OCE Office Equipment & Supplies
Can"t get it to scan. not on wireless.HP 4780 photosmart
You are saying that the printer/scanner is directly connected to the computer?
You need to start checking the physical connection. Make sure that you can print to make sure that the printer is being recognized by the computer.
Second, try uninstalling and reinstalling the printer/scanner driver using the CD that came with it. Most of the time, it's the driver that causing the problem.
Hope this helps and have a good day!
Nov 27, 2009 | HP Photosmart C7280 Laser Printer
How do i reset the maintenance light that is on because i cannot find my manual
you can go to a parts store and they have a scanner that will turn it off. Or, you can disconnect the battery for about 30 minutes to reset it. You will have to reset the clock inside.
However, by reseting it, it may come back on if the problem isnt fixed. The parts store can scan it and tell you what is the problem.
Oct 29, 2009 | 2003 Lexus LX 470
How to turn off maintenance req'd warning lights on dash
this light 7407fc2.jpg correct? to troubleshoot this light, the car can be scanned with any OBD2 scanner/code reader. after it has been scanned, the scanner will have an option to erase all codes. once they have been erased the light will go off.
the only other way to make the light go off is to disconnect the battery for 15-30min. this will reset the engine ECU, causing the light to go off but also will erase any codes that may be stored in the EC
U. if the ecu resets and car is started and detects the same problem the light will come back on.
Check to make sure that the fuel tank cap is on tight.
When the fuel tank cap is loose:
The electronic engine control system warning light comes on as a temporary malfunction.
Oct 14, 2008 | 2007 Lexus IS 250
SVC Scanning
Reset scanner by powering off, press the Hold,2 and 9 keys all at the same time and turn on the scanner.
Sep 07, 2008 | Uniden BC370CRS Base Scanner
Computers & Internet Logo
274 people viewed this question
David Payne
David Payne
