Question about Karcher 2500 PSI Pressure Washer
If while pressure washing I let off the wand trigger it looses pressure and I have to turn of the washer motor and wait for the pressure to return.(seems like some kind of vapor lock problem)When the pressure returns I hold the trigger and restart the washer. If I let off the trigger we go through the same process again. this is a g3050
  • lewis_brewer Mar 15, 2011
    thank you pier I'll give it atry.
  • lewis_brewer Mar 18, 2011
    Sounds promising..will give it a try. Thank you
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
This is most often caused by the bypass / un-loader valve located on the high pressure output side of the pump. The valve will either have a stem type valve with a knurled locking nut or a cap. Both of them retain a valve and plunger with at least 2 seals. The valve pin and plunger stick in a dirty / corroded housing.
Your parts break down can be found here:
http://www.ereplacementparts.com/karcher-3050-11945150-pressure-washer-parts-c-33388_33389_34002.html
The items that are causing your problem is item 1, 2, 3 in detail B of the above link. You will need to remove these items and clean up the pump housing and all of the parts. Clean the pump housing thoroughly. Use a rolled up piece of fine grit sand paper if necessary to remove any corrosion or rough spots in the housing. As for the stem, o-rings and seals they must also be very clean. DO NOT use sand paper on any seals. Once everything is very clean including the spring you must lubricate everything including the pump housing with a liberal coating of #105 White grease that is available at any automotive parts store in small tubes.
After cleaning and lubrication, reassemble the unloader / bypass valve and re-install same.
This should make it work normally again IF all of the seals of item 1 are in good shape. If you discover a damaged valve / damaged seals (item 1) it must be replaced.
Thanks for choosing FixYa,
Kelly
Posted on Mar 15, 2011
  • 2,428 Answers
It sound like one of the valves in the pump is jumbed .Find out what kind of water pump is on the mechine it will say on in This is a relitively small mechine its good for wells 2.5 gal per munite Whats normanly happens it the cages for the valves and made of plastic and peices tend to braek off and stick in the valve most of the time if you take the cap off the valve head you can pull the peice out and it will work fine again Look at the pump you will see 6 caps on the pump body that can be removed with a large socket the problem is you need to remove them all one at a time to check them all because there may be more then one that is broken . You can also buy a valve kit for 60 or so dollars and replace all of the valves but you probably won;t have to . Why this happens it because your not suppose to let the mechine run at high RPMS with the trigger pulled so idal it down when ever you can when the trigger is not pulled . Iknow sometimes its not that practial what if your on a roof but this sounds like what your problem is i do a lot of powerwashing and rebuilt these things on the side . And if the pump is a MITI M pump it happens all of the time
Posted on Mar 14, 2011
Pressure washer was working fine then it shut off. and now I cant pull the string
Whoa! Wait when water pressure is at hose you have to pull the trigger on wand to release pressure so the engine can turn freely. It has so much pressure at wand that it will not let you turn enging over. If not It may have froze up. Check the oil first , no oil then it is locked up. If not you can remove pull rope cage and try to turn it manually.
Oct 01, 2014 | Garden
As soon as I turn the water on, it comes out of the gun and high pressure turbo wand even with the machine off. I used it yesterday with no problems. It does this without even pressing the trigger. ...
This part should be available from the manufacture, have you check their website. It is normal when you turn the water on for a small string of water to come out the gun when you press the trigger even when the engine is not running.
Thanks
Jun 03, 2011 | Black & Decker 1700 PSI Electric Pressure...
My Snap-On 2000 PSI pressure washer is leaking through the trigger handle. I have no pressure coming out of the wand but the motor runs.
The fitting for the trigger is cracked. It happened to mine because I did not make sure the wand and hose was drained before winter came. The water left in the wand expanded and cracked the trigger housing. The problem is that the trigger piece is easily replaceable, but it is not available. Alltrade makes you buy the complete wand.
May 12, 2011 | Garden
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Let go of wand trigger pressure will not come back
spill valve is stuck and needs to be cleaned and greased common problem....also check all connections for blockage in line
Jul 21, 2010 | Karcher 2500 PSI Pressure Washer
Shuts off when high pressure wand is attached
Hi Brian. Welcome to FixYa I am Kelly. This sounds as if the bypass / unloader valve is stuck in place and the pump id dead heading causing the unit to shut off. (There is most likely some corrosion in the unloader / bypassy valve assy / housing. What you can try is pouring at least 3 oz of oil into the water inlet assy and briefly.... like VERY briefly switch the unit on then back off. Then let it sit over night. The next day connect everything for normal use then turn the unit on again briefly. Use a bucket to PURGE the oil that you put through the system by squeezing the wand Power SW Off until the oil purges. Then switch the unit on and rapidly trip the trigger at 0.5 sec intervals or less. If it trips off wait 5 mins and try it again. Do the rapidly tripping the trigger on the wand routine for about 20 seconds. Your forcing the bypass unloader valve to cycle trying to clear out any debris / corrosion.
This works often and well. There are exceptions. Hopefully it will work for you.
Thanks for using FixYa.
Kelly
May 07, 2010 | McCulloch FHH18A Electric Pressure Washer
My Troy Built pressure washer shuts down when I turn on the water. Is the pressure cut off valve that might be frozen?
Hold the trigger of the pressure nozzle open. Turn on the water . Wait to see water coming out of the pressure wand.Then try and start the engine. They can get air locked.
Feb 12, 2010 | Karcher 2500 PSI Pressure Washer
Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
No high pressure no leaks motor runs off and on when trigger is released
check filter in wand and clean out nozzle hole for starters
May 04, 2009 | Garden
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Karcher 2500 PSI Pressure Washer Logo
739 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
