Question about HP LaserJet 2420 Printer
Install black cartridge message on HP Laserjet 2420 printer while inserting new cartridge
  • HP Master
  • 1,915 Answers
If you still have your old cartridge, install that to see if the printer works. If it does he new cartridge has a bad chip on it and should be replaced by the vendor.
Posted on Mar 15, 2011
My hp 2420 printer ask me that you ink is at end of life.i refill ink and now when i insert it again their is message replace black cartridge.for print eveytime i have to open and close the cover
You have to buy an original toner for this printer and not refill. the toner number is
11A or Q6511A or u can buy from this website
http://h10010.www1.hp.com/wwpc/us/en/sm/WF13a/18972-18972-3328059-14638-3328069-416419.html?submit.y=8&submit.x=4&lang=en&cc=us
pls rate solution after wards
Nov 15, 2011 | HP LaserJet 2420 Printer
Hp lajerjet 2420 install black cartridge msg after toner refill and new toner insert then ok
  1. The cartridge toner (q6511A or X) is damaged.
  2. The smart chip on the toner cartridge doesn't work.
Jul 20, 2011 | HP LaserJet 2420 Printer
You take your chances with any non HP cartridges. Especially when they are refilled. If it came with a warranty...use it.
10.00.00 supply memory error
The 10.00.00 SUPPLIES MEMORY ERROR is based on the e-label. To clear the error, do the following:
NOTE: If the error occurs, it should appear at beginning of life, causing the error message after first installing the cartridge.
Turn the printer off and on to clear the message.
Put in the old catridge and see what happens.
If OK put in the new one again.
Verify that the print cartridge is a genuine HP cartridge.
Check that the E-label reader is functioning correctly.
Check that there is contact between the E-label chip on the print cartridge and the E-label reader on the printer.
To verify this contact, insert a new print cartridge.
Remove it again.
Check for scratches on the e-label chip and on the cartridge.
If contact is being made, replace the print cartridge (part number: Q2610A).
If contact is not being made, check the toner guides to see if they are in the proper position, or that the cartridge is not damaged.
If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
Turn the printer on again.
If the error does not clear, turn the printer off and remove tray 3.
Turn the printer on and verify if the error clears.
HP has recently discovered that a 10.00.00 Supplies Memory Error can occur when Tray 3 is faulty.
May 06, 2010 | HP LaserJet 2420 Printer
Question on a 52.00 error message on an HP LaserJet 2420dn.
Look for a broken tab on top of your cartridge; if you have one, the laser safety interlock is not being opened when the cartridge is inserted. Install new cartridge.
If you don't have cartridge damage, there may be a failure of the laser assembly or (less likely) the engine controller board.
Nov 16, 2009 | HP LaserJet 2420 Printer
Hp laserjet 1012 printing black pages
dark background usually means the High Voltage Power Supply is malfunctioning.
replacement only.
Jul 05, 2009 | HP LaserJet 2420 Printer
PRINT FADING ON RIGHT HAND SIDE WHILE BLACK CARTRIDGE SHOWS FULL.
your cartridge is third party toner insert new hp original cartridge before cleaning
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
Apr 04, 2009 | HP LaserJet 2420 Printer
Printing with 6 black dots on right side
If the spacing between dots are the same, then you have a dirty or bad roller. If you never had this problem prior to installing the new toner cartridge, then I would suspect you have a bad one. Try a different toner.
Nov 18, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
293 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
