Question about Sub-Zero 632 / S
Water will not feed into the ice maker is there a pump or switch that may have friezed out?
  • 33 Answers
There is one but it's not something easily accessible. The entire door needs to be taken apart and will be very hard to put back together.
Posted on Mar 14, 2011
Whirlpool ice maker will not fill with water
1st check to see if fill tube is frozen that goes through back freezer wall to feed water to ice maker. If it is, thaw it and replace water valve. If not frozen, then you must determine if water valve or ice maker is bad. You must determine if Ice maker is sending voltage to valve. If it is, replace valve. If it's not, replace ice maker.
Sep 03, 2017 | Whirlpool Refrigerators
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
Have a HOTPOINT CTX18GI fridge. Automatic icemaker doesn't work, but don't know if it's the actual ice maker or any of the switches. Water is going to the line from the sink plumbing via a standard small...
Have you tried raising the arm of the ice maker and leaving it for awhile then push it back down and see if it will work? Should be a cover that is over the plug take the cover off and unplug the ice maker, shouldn't be that hard to take off. I believe you have to squeeze the top and bottom together to remove it but Im not positive.
Nov 09, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Ice not friezing completly and then water forms ice on icemaker ejection blades causeing them to get stuck and will not turn to eject ice ?
could be the auto defrost timer is running too long you can not adjust it but before you start troble shooting it check the door seals carefully they are typicaly magnetic and some times get deformed some place you might not notice tell tale indicator is tiny ice crystals around the edge near the seal...a little hot water poured on the ice maker will typicaly dislodge that frozen block.. good luck... nothing worse than no ice after a long day at work :-)
Oct 23, 2009 | Amana SXD524VW Side by Side Refrigerator
Water in door but no ice?
there is no pump, just water psi from your house.
check inlet valve to ice maker/water float
Sep 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker dont make an ice. can be water pump problem?
If you're getting water in the tray the pump isn't your problem.
Where if you're not getting water fed into the tray before citing the pump. First check for a clogged or pinched line as well as where you tapped into your water line feed.
See unless your unit's freezer isn't refrigerating properly at a refrigerated temperature. There's no other reason why your unit wouldn't be producing ice from the feature.
That's regardless to anything else
Jul 27, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Too much water is being dispensed when filling to make ice cubes. Water pours into ice bin and freezes. What to do?
You have to close the water supply tap from the source a little. This will decrease the volume of water being pumped into the ice maker. If this doen't work then you need to replace the solenoid valve that feed the water to the ice maker.
Jul 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker
The water valve appears to be the problem. The water valve ,located on rear of ref. at bottom has two (2) sides to it. One side feeds the water to the water dispensor and the other side feeds the ice maker..
Jul 07, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Ice maker isnt working...
just clearing this post from hte questions not answered list!
Mar 22, 2008 | Amana SXD524VW Side by Side Refrigerator
Sub-Zero 632 / S Logo
125 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
