Question about Apple iPhone 3G
My iPhone won't charge. When i connect it to charger, it shows red battery with a volt symbol??? Then the iPhone turns on and shows that i have less that 20% of battery remaininh, so i leave i connected to charger but nothing happens, the battery doesnt charge, it stays red and does not show up the charge symbol. I tried charging with computer and wall, i also used three different usb cables, still the same problem. Could it be my battery that is the problem
  • 643 Answers
Your battery seems to have a damaged cell, replace the battery and it should run fine
Posted on Mar 14, 2011
Viking battery charger 63350 continuously flashes .09v Is the normal? Charger is connected to battery for 12 hours.
If the battery is under 10.5 volts, the charger will try to recondition the battery for about an hour. After that it will either charge normally, or show the bad battery symbol. Look at this review f three chargers with yours starting at about 7 minutes. The charger starts at 6.1 volts so your charger may be bad:
https://www.youtube.com/watch?v=TyDL5TM0Oko
Apr 03, 2018 | The Health & Beauty
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
My iphone 3gs won't turn on. If i plug it into charge then it comes up with a small red line on the battery symbol (like the battery is about to run out) and a lightning bolt symbol. If i unplug the...
Sounds like you have at least a broken battery. Apple should give you a replacement. If you're out warranty, you can try to open it and replace battery. If that fails you need a new logic board. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
May 18, 2010 | Apple iPhone Smartphone
Cect p168C will not power on
  1. Turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  2. If that doesn't work, connect it to the iPhone charger and let it charge for at least 10 minutes. Note: iPhone 3G does not support FireWire and will not charge from any FireWire-based power source.
  3. If that doesn't work, toggle the ringer switch to see if the unit vibrates. If it does, it could be that iPhone is getting power, but is not displaying any image. (see "Display has no backlight or dark screen" below for further troubleshooting.)
  4. While connected to the iPhone charger, try to reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPhone until it is fully charged.
Oct 16, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
315 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
