Question about Belkin 900VA ( F6C900-UNV ) UPS System
What doies it mean if the unit turns itself off, resulting in a loss of power to my electronics?
  • 27 Answers
Most likely your battery is dead in the UPS. Replace the battery if you can. Belkin should be able to help you with that.
Posted on Mar 14, 2011
Powerwent off while furnace was heating, when power came back on, furnace would not start
The unit probably locked its self out, meaning a safety sensed the power loss & will not let it restart until it is reset. If you can unplug, this will reset the system. Or make sure the breakers are not tripped. A power loss also creates a power surge due to the fluctuations in power supply. This fluctuation has the potential to damage circuitry at the control board in the unit.
Feb 17, 2017 | Heating & Cooling
How can I fix
Hello, try to clean and dry the electronic board, sometimes the humidity make shortcircuits between logic gates.
Oct 24, 2014 | Senville 18000 BTU Ductless Air...
We had a power loss and when the power was restored the readout for my range said F1. The burners work, but not the oven.
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 29, 2011 | Amana Ovens
I have noise occasionally from my headrush 2 can i have someone modify it seems to click on and off at times
Most common cause is loss of power due to poor connection. These are usually turned on by plugging in the inout cable and a worn plug from the guitar may be intermittent. The sleeve of the inserted plug usually turns on the battery or the adapter power to the unit. Adapter plugs are notorious for poor connections. Another common problem is broken solder at the external jacks into these as cords get yanked and stepped on resulting in force on the jacks breaking the solder. A momentary power loss will trigger the unit off.
Jul 19, 2011 | Akai E2 Head Rush Headrush Guitar Effects...
Loss of power nothing working
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.......
Regards.
Apr 15, 2011 | Maytag MMV4205 Microwave Oven
My tv box that powers my sony tv turns itself off after i turn it on. how do i fix it if the box and parts r discontinued?
Without the specific make and model I can not comment on whether or not parts are available. But in general, specific parts (cabinet parts for example) are available for 5-7 years after introduction. The internal electronics parts are usually available longer than that as they are generic and used by many manufacturers in their own units. Should the specific part be unavailable, there are often substitute parts that can be used without any loss of quality or function.
Dan
Dec 08, 2010 | Televison & Video
What does it mean when the ESP light comes on in a Kia Sportage Year is either 2005 or 2006
2005 Kia SPORTAGE Recall ID from NHTSA: 05V120000 Auto Recall Date: 03/29/2005
Vehicle Component: SUSPENSION:AUTOMATIC STABILITY CONTROL (ASC)
Estimated Vehicles Affected: 7619
2005 KIA SPORTAGE Defect Summary:
ON CERTAIN SPORT UTILITY VEHICLES EQUIPPED WITH ELECTRONIC STABILITY PROGRAM (ESP), THE YAW RATE SENSOR MAY BECOME TOO SENSITIVE AND MAY RECALIBRATE INACCURATELY. WHILE DRIVING THE ESP PROGRAM MAY CAUSE THE ENGINE TO REDUCE POWER AND MAY CAUSE A BRAKE AT ONE OF THE WHEELS TO BE INAPPROPRIATELY.
Defect Consequence:
BRAKE APPLICATION CAUSED BY INADVERTENT ESP ACTIVATION MAY RESULT IN LOSS OF CONTROL AND A CRASH.
Remedy:
DEALERS WILL REPROGRAM THE ESP HYDRAULIC ELECTRONIC CONTROL UNIT FREE OF CHARGE. THE RECALL BEGAN ON APRIL 13, 2005. OWNERS MAY CONTACT KIA AT 1-800-333-4542.
Notes: KIA MOTORS AMERICA, INC., SC-044
Oct 13, 2010 | 2005 Kia Sportage
The monitor is plugged into the power, and connect...
Guest, You will need to "sub-in" a known-good monitor to prove your pc is working ok! If pc is ok, then plug-in bad lcd monitor and check ( test ) it with aid of a bright flashlight to see if you can see a very faint image of the WIN-desktop being displayed on the now "black" LCD panel. Every owner of "cold-cathode-fluorescent-lamp back-lit lcd monitors should know the "flashlight test" and understand what the results of this very basic test mean. Do some reading in my old (louie12fix) profile to learn how to do test. Hint: The very first thing I would investigate inside the unit would be the unit's "switch-mode-AC to DC-power-supply/ccfl electronic ballast circuit for the top two causes of power supply going into "partial or full" shutdown mode, trying to SAVE itself from a nonrecoverable catastrophic failure. e.g. sparks,smoke, fire!! 12fixlouie
May 20, 2010 | Computers & Internet
All of a sudden, my 2004 Ford Taurus heater control doesn't work. Hot air ALWAYS comes out, no matter where the temp control is set. Even if set in AC mode the air is VERY HOT! Help!
The valve (called the heater tap) which controls the hot water flow works from engine vacuum. The climate control unit turns vacuum on to close the valve and turns vacuum off to open it, if the vacuum tubing or vacuum service valve has failed, the tap will be open allowing hot water to flow. The same result applies if the heater valve itself has failed (which they do --regularly) Trace the water hoses from the enginebay firewall under the hood and you should find the valve. Check for cavuum at the valve with the climate control set to its coldest setting. If you have vacuum at the valve, replace the valve. No vacuum points to the loss of vacuum source or a faulty vacuum service valve with will be electrically operated from the climate control. Trace the vacuum hose from the heater valve back to the vacuum service valve and check if the valve has vacuum supplied to it. No vacuum means a vacuum hose has blocked, has a hole in it or has been removed from the manifold. If the electrical valve has vacuum, check for power. If power is present but still no vacuum at the heater tap, replace the service valve. If power missing, check fuses. If both wires to the valve show power present, have the climate controll unit checked by a professional..
Oct 31, 2009 | Ford Taurus Cars & Trucks
Belkin 900VA ( F6C900-UNV ) UPS System Logo
146 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
