Hi.i cant seem to find switch on /off buttons on this model dimplex SHB20L.i plug it in but its not heating up so there must be a switch somewhere.cant locate it!!searched for manuals online but to no avail.it is a really silly problem but i need to solve it!!any help would be appreciated.thanks.
    Brigadier General:
  • 4,736 Answers
Contact Dimplex USA, Technical Service 888-346-7539. I'm sure that they can help you.
Hope this helped you.
Posted on Mar 15, 2011
How do i replace the on/off switch on dimplex fire? Model Number MON20R
https://www.manualslib.com/manual/762887/Dimplex-Rec20r.html&ved=0ahUKEwjmgaXO4rjTAhUJzoMKHVkpAfoQFgghMAM&usg=AFQjCNHqq7ZBbHJC6PuRMVx_G3BQsFOJ5g&sig2=EqzuIoMZYeySCbFSE_BHRQ
Apr 22, 2017 | Dimplex Heating & Cooling
How to cure a noisy fan ?
Hiya! These fan units are a royal pain in the neck!
What you need to do, is get to the fan unit, remove the motor from the blade (they usually have a twist and lock bracket held on by a single screw)
The motors for the blowers are just simple shaded pole motors but these often dry out due to dust, and heat over time.
The best cure is to unscrew the motor and pull the shaft and rotor off of the front and back bearings... clean the shaft thoroughly of any debris and set aside.
Then, you want some light sewing machine oil (easily obtainable in most fabric stores) and you want to drip it around the outside of each bearing so the oil absorbs into the pads around the outside of each bearing. Add a smidge of oil to the inside of each bearing too, before reassembling the motor.
Make sure the motor screws are as tight as possible, and then with a screwdriver handle or similar instrument, give the motor shaft a few taps on one side, then a few on the other (this will align the bearings correctly.
Before reattaching the motor, on the other side of the fan unit you will see a little round metal or plastic cover held in place by a rubber gromit. This is the access to the spindle bearing. Pop this cover off and replace the grease under it, add a bit of machine oil too if you like (it cant hurt) and then replace the cover.
Reassemble everything again, and test.
May 08, 2014 | Dimplex Compact Electric Flame Stove...
Just purchased a dimplex DS5629 electric stove. Plugged it in, but NO HEAT and NO BLOWER. Dimplex is closed for the weekend. NOW WHAT???
Ar e you sure that the receptacle your have it plugged into is working? If it is, you can try this. It usually works. Turn the Master On/Off Switch to OFF. Unplug the unit and leave unplugged to 12 - 15 minutes. Plug the unit back in and turn the Master On/Off Switch to ON. Then, turn each individual function one at a time. If they ail function as they should, the unit has reset itself.
If it doesn't work, then you'll have to wait until Monday to contact Dimplex OR you could contact the retailer you purchased it from and have them replace it immediately. That is, unless you purchased it online. Then, it would be better to wait until Monday and contact Dimplex. Be sure you have your Model Number and Proof of Purchase, when you contact them. In case you don't have it, their Technical Support number is 888-346-7539.
Hope this helps you solve the problem.
Apr 01, 2011 | Dimplex DS5629 Electric Heater
Hi, I don't know what the reset switch on my dimplex ofc2000ti looks like, anyone any ideas? Power to unit but not heating up, all connections inside fine. Hopefully it overloaded and tripped.
Turn the Master On/Off Switch to OFF and unplug the unit from the wall receptacle. Leave it unplugged for 12 - 15 minutes. That should give it enough time to reset itself. Then plug it back in and give it a try. Also, make sure that the wall receptacle is working properly and hasn't tripped the circuit breaker in your home's circuit breaker panel. If it did, something is seriously wrong electrically, with the heater.
Hope this helps you solve the problem. Please don't forget to rate my response to your question.
Thanks!
Mar 25, 2011 | Dimplex OFC2000TI Heater
Hi, Last night none of the Dimplex storage heaters in my home came on. I checked the fuse box and nothing has been trippped. They were working fine the night before and I cant think of any reason why they...
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Dec 15, 2009 | Dimplex DS5603 Heater
I need to know how to operate a dimplex eva20 evaporative cooler I have no operations manual and cant seem to find one?
hi :) ,
i'm guessing your in australia ( i'm in scotland ) , i cant find a manual online for your model of evap cooler , but heres the link for there tech support dept
http://www.dimplex.com.au/contact/
in the message box request a pdf of the manual for your model of cooler
hope this helps
Nov 09, 2009 | Kitchen Appliances - Others
Dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Feb 05, 2009 | Dimplex Compact Electric Flame Stove...
No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
