Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote stopped working all together. Replaced the remote and it still doesn't work. Tried replaceing the batteries as well. Light on remote flashes but that's about it. It is a Sharp Aquos HDTV not sure of the model, tv is hard to access to see model #.
  • 31 Answers
If the TV still works fine and it's just the remote malfunctioning, try removing the batteries from the original remote and leave them out for 10-15 minutes. Put the batteries back in and try the remote.
Posted on Mar 14, 2011
I have a Panasonic surround sound DVD player and the remote has stopped working, I've replaced batteries and tried resetting unit.
Did you fully shut down the player including unplugging. Did you contact mfr customer service or warranty claims for instructions on resetting the remote code in the unit?
Jan 13, 2015 | Panasonic Televison & Video
Infrared indicator light will not come on all buttons flash multiple times
um..you wont see the infra red with the naked eye..you can only see it using nite vision style equipment..something that shows in monochrome which is that frequency..if it lights up it is supposed to be working..some need reset to the units in use when the batteries are replaced..use the search mode on it..
Feb 06, 2014 | Universal Urc R6 Avex Pre-Programmed...
Light wont stop flashing
Light flasher will not stop flashing.
Jan 13, 2014 | RCA Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Wii remote not working?
You got to sync the remote with your console to activate the remote
Aug 09, 2017 | Nintendo Wii Console
My remote wont work it says set 1
You can try this simple idea; to re-code the remote to your unit, press and hold 1 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore the remote command to match the unit, and thus the remote should work. Failing that, replace the batteries in the remote with new ones, and repeat the above suggested procedure.
If the remote is triggering 'SET 1' on the unit's display, this simply means the remote code is different to the unit, and hence the remote requires a reset to restore control to it whenever the batteries are replaced. Easy enough to fix, doesn't take very long, and should not cost anything except some new batteries if required.
Apr 28, 2011 | Panasonic DMRES15 DVD Recorder
I have the gict390 - 1 button--- it used to work on my garage - doesn't anymore. Wife's remote still works. Tried reprogramming - didn't work. The led on it still works & haven't had it that long...
My remote stopped working and the light still came on as well. Replaced the battery and it's working again. Try the battery. Tip: when I took the shell apart, I had to take the circuit board completely out of both halves of the shell to get to the battery.
Sep 14, 2010 | Genie Company IntelliCode GICT390-1BL...
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Emerson Video Cassette Recorder remote does not work..model # EWV404
Try pulling your original remote apart and clean with metho let dry for ten minutes then put it back together. As for universal remote what sort of remote Make and model of remote?
Jul 23, 2008 | Emerson EWV403 VHS VCR
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
283 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
