Question about Sony Playstation 3 (PS3) Console
Our playstation 3 does not read any game disc's but we can still access the hard drive?
    Problem Solver:
  • 18 Answers
Since the disc drive and hard drive aren't linked, the disc drive can fail while still allowing you to access all the data on your PS3.
Unfortunately, if the disc reading problems continue, there's very little you can do about it yourself. It's possible the lens reading the discs has becomes smudged. You can try a disc cleaner to see if it helps.
If not, you will likely have to send it in for repairs, which may be expensive. Make sure you backup your saves and other files to a USB drive before sending it. Good luck!
Posted on Mar 14, 2011
Playstation don't read cd
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Take care.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
The playstation 3 wont read discs. Regardless of what disc I put in, DVD, Bluray, game or CD it just wont read. I'm pretty sure that it's not spinning the disc because it doesn't make the humming sound it...
You could buy a new Bluray drive and swap the dead one out. They cost around $80 and aren't hard at all to swap out. You could also try to lubricate the shaft of the drive motor, as it may just have ground to a halt from friction. Other than that, there's not much other than getting a repair/replacement from Sony.
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
My playstation will not play any games, nor movies. system # 98006
hello,
The most common reason for the Playstation not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Playstation including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Playstation going again!
May 19, 2010 | Video Game Consoles & Games
My ps3 will not read discs. I can play off the hard drive and the system seems to know there's a disc in it but willot access it. what can i do?
There isn't much that you can do besides taking the PS3 apart and cleaning the laser with a q-tip.
In 9 / 10 cases the laser needs to be replaced.
Check out this website for more info.
Apr 05, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 won't read discs anymore, I have tried cleaning it and reformarting the hard drive
If this is a older model playstation 3 then all you need to do is get a laser disc cleaner and follow the directions and your ps3 will run like new.
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
Wont read blu ray discs
its because your lens kit are defect search on google for replacement lens ist about 80$ usd its not really hard to replace but verify that your warranty is over before lol
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
Won't read disc in hard drive
yes you do need to get the drive cleaned you can get a laser disk that cleans it from either game or playstation or maybe online they usually work
Jul 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
