Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you get the hose out to vacuum steps - Dyson DC07 Bagless Upright Cyclonic Vacuum
How to attach part to clean steps
on the front hood there is a round port connection to open and then insert and turn to lock in the suction hose. On the side there is another connection for the solution hose.
Sep 05, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Tip
Vacuum cleaners: Loss of Suction
A common complaint about vacuum cleaners, regardless of the brand, is loss of suction. The motor runs fine, there seems to be plenty of power, and even some suction, but the vacuum just won't pick up even the lightest of items. There are some very simple checks and fixes to this problem most of the time.
The primary causes are: clogged hose, full bag, leaky hose.
Clogged hose: this is probably the most common cause, and will result in a damaged motor if not cleared.
Check: Remove hose from vacuum and wands. Holding one end, drop a marble or small ball into the opening and allow to roll through. If it doesn't come through the end, then the hose is clogged.
Solution: If you have a canister vacuum with an exhaust port, try connecting the hose to this and turning machine on. If the clog isn't too bad, this may clear it. If not, more extreme measures may be needed.
Never attempt to clear a clog with a coat hanger or similar length of wire, as this could easily puncture the house. Do not use water or high air pressure gun to clear hose.
Full bag: Check bag. Change if necessary. If it seems the bag should hold a little more, well, it's not worth replacing a motor, or the vacuum, trying to find out. Bag pores are easily clogged if the machine is used for cleaning construction areas where sheet rock dust is abundant. Ensure you’re using genuine bags for your machine.
Leaky hose: Over time, hoses suffer from normal wear and tear, and often abuse, resulting in cracks and holes, often too small to notice. Hoses need to be replaced at this time, and this generally results in a dramatic increase in "suction". There simply is no fix for a leaky hose.
Solution: Always store the hose properly to avoid kinking, crimping, smashing, etc. Avoid stepping on the hose, or leaving in an area where it may get stepped on , driven over, or smashed. Avoid pulling the vacuum by the hose, or otherwise stretching/stressing the hose.
on Aug 22, 2010 | Vacuums
Red light on then cuts out how do i unblock please? lost the manual.
Hi There,.
So when this light is displaying, it's says "Bag Full or Clog" on the indicator. If you have changed the bag, and it's still showing this light, it means that you either have a clog in the vacuum, or your filters are dirty, which is reducing the suction and making the machine think that your bag is full. If your machine is actually cutting off, this indicates that your machine is definitely clogged, or something is stuck inside which is causing the motor to not get air flow, and cauing the machine to over heat. When it shuts off like this, it's a protection system that prevents any damage from happening to the motor when it can't breathe and starts to overheat.
My guess is that there is probably a clog in the machine somewhere, or the filters are dirty. Here's what you may do to diagnosis the machine, and try to isolate the clog to find out where it is in the vacuum.
Step 1. Remove the hose and wand assembly from the vacuum cleaner completely. You may do this by pressing the two tabs on the end of the hose that plugs into the vacuum cleaner:
With the hose and the wand removed from the vacuum, it should look like this:
Step 2. Now turn the vacuum cleaner on and check to see if the red light comes on while the hose and the wand have been removed. If the light comes on, then this indicates that your filter is dirty (or the PCB electric board is bad if the filter is clean) and needs to be replaced.
Step 2. Re-attach the hose and wand back on the vacuum, but just the end of the hose that goes into the vacuum cleaner, leave the wand out of the vacuum cleaner so it looks like this:
Turn the machine on now as if you were using the attachment hose to clean corners or above the floor and see if the red light comes on here. Also listen to the noise the motor makes and see if the noise changes when you put the hose back on the vacuum cleaner. If the red light appears, or if the motor makes a higher pitched noise now, then this indicates that you have a clog in your hose or wand. You may verify this by remove the hose again from the vacuum, and also removing the wand from the hose by pressing the hose release button on the wand and pulling the hose out of the wand. Look down both of the parts and see if you can see thru both sides. If you're not able to see light through the hose, or the wand, this indicates this is where the clog is. You may take a metal clothes hanger, and try removing the clog this way.
Step 3. If the red light did not display with the wand not inserted into the vacuum, put the wand back into the vacuum cleaner as if you were vacuuming the floors:
Turn the machine on, and see if the red light comes on in this position. If the light does come on, then this indicates that you have a clog in the bottom of the vacuum cleaner. To check and see the clog in the bottom of the machine, I find it easiest to remove the upper bag housing from the vacuum cleaner completely so you're just looking at the bottom power nozzle of the vacuum cleaner. There's a button at the bottom of the machine that is either a grey, or yellow color depending on what color your vacuum is. Simply press this button in, and lift upwards on the handle or the bag housing at the same time:
Step 4. After the bag housing has been removed, turn the lower part of the vacuum upside down so the brushes are facing upwards. There's a little orange flap on the bottom of the machine that is actually a clog port. Almost every time there is a clog in a Sebo, this is where I typically find the clog. Open up this orange colored trap door, and look to see if you can see any obstruction or clog underneath of here:
Step 5. You may rotate the neck of the power nozzle part towards you so that you may look inside to see if you see any obstructions inside:
Step 5. You may also remove the brushes from the vacuum and look behind the brushes at the suction port, or the area where the suction goes through the vacuum to see if you see anything obstructing the suction here.
These are really the only places that the Sebo can get clogged. If you checked all of these areas, and the red light is still displaying, this means that your PC Board that controls this indicator has gone bad, and needs to be replaced. If this is the case, please just reply to this repair using the comment field, and I'll be more then happy to help you through the replacement of replacing the PCB Board.
I hope this answer was helpful to you, and you were able to find the clog and fix the problem. If you found my repair helpful, please be sure to rate the repair
Aug 09, 2012 | Sebo X4 Bagged Upright Vacuum
How do you get items out of the vacuum hose that are stuck?
I'm sorry to hear you're having difficulty with your DC25 Animal. To remove a blockage from the hose, please follow the steps shown in our online Support guide for this issue:
http://www.dyson.co.uk/support/dc25/dc25-animal/how-to-use-your-dyson-vacuum/how-to-remove-a-blockage/removing-blockage-from-wand-and-hose-step-1
This should resolve things, but if you'd like any further assistance or advice, please give our customer Helpline a call on 1-866-693-9766 (US), or 0800 298 0298 (UK).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Aug 01, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Removing the hose
Hi Carol,
I'm not sure from your question whether you want to remove the hose from the machine to use it, or to replace it. For a step-by-step guide on using the hose, wand and accessories, please visit our Support page for this machine:
http://support.dyson.co.uk/support/dc24/dc24-multi-floor/maintaining-your-dyson-machine/how-to-use-accessories/how-to-use-the-combination-tool-step-1
To remove the hose from the machine in order to replace it, this guide may be useful:
http://support.dyson.co.uk/support/dc24/dc24-multi-floor/how-to-use-your-dyson-vacuum/how-to-remove-a-blockage/removing-blockage-from-wand-and-hose-step-1
I hope this helps - if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Feb 23, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Blockage when using hose
I'm sorry to hear you're having difficulties with your DC24. If the hose or wand appears to be blocked, the easiest way to locate and remove any obstructions is to follow the steps shown in our online support guide:
This should resolve the issue, but for any further assistance, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Jan 14, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Vacuum shoots dirt or whatever it has just vacuumed out the back of the vacuum. I checked and cleaned the filter and the vacuum bag and it still leaves dirt behind the vacuum.
Good morning,
If you've checked both the bag and the filter, the next step would to check for any clogs.
I will detail what you will need to do below, or you can always reference your Owner's Guide (check: How to Check and Clear Hose Blockages)
http://www.eureka.com/service/manuals/77418_r2.pdf
Step 1: Remove hose from hose retainer on the base and check suction at end of hose - if little or no suction, check dust cup. Empty if needed. If no improvement, proceed to step 2.
(Make sure you turn off the switch and unplug the unit before proceeding to step 2)
Step 2: Remove electrical cord from cord hooks. Disconnect the clear tube by unscrewing the 2 screws, then lift away from cleaner. Check for any obstructions that may be in the tube or hose. Any obstructions can be removed by using a blunt instrument to clear the tube or hose (I will sometimes you a bent hanger or a retractable pointer). Flexing the hose may help loosen the blockage. After clearing blockage, reverse above steps to reassemble unitpcfloy86_0.jpg.
I hope this helps. If so, please give this solution a thumbs up!
Have a good day
~PCF
Mar 05, 2011 | Eureka Power Plus 4703D Bagless Upright...
Where do i plug the hose into the vacuum
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Jun 15, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Low Hose Suction, Hose is open.
thanks for the clarification.
since the hose in unclogged, the next place to look is in the body of the vacuum.
there is usually a tight turn in the dirt channel in the base. often you can see the clog if you remove the hose.
the next step is to dissasemble the base and look for the clog.
does the motor sound normal?
is the impeller turning at a normal fast rate?.
Jan 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
19 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
