Question about Dell NPS730AB 730Watt Power Supply
I Like to use the Dell PowerEdge 2600 Mfr P/N 7000679-0000 (supplier ATSN) power supply stand alone. Could you please provide me the pin-assignments on the connector?, for 12V Your help is highly appreciated
  • 1 more comment
  • ricky Jul 31, 2012
    atsn mdoel 70000679-0000 730 pinout did not work like you guys said to do
  • Rat 9
    Rat 9 Nov 02, 2012
    http://i45.tinypic.com/2rzdjl5.jpg
  • Ray Samples
    Ray Samples Nov 09, 2017
    Very easy.. connect A6,C5 and D6 together and it will turn on.
    On my power supplies the A1 ( ground ) was not functional for some reason.
    If you want switch control for output do this..
    A6 and C5 connect to 1 side of switch, and then D6 connects to other side of switch
    (single pole switch)
    Good luck !
    Problem Solver:
  • 5 Answers
The fact that it is a dell IS relevant because dell is always doing custom plugs and connectors and form factors. It has no ATX plug. This a server power supply and has no green wire. I would like to use this as a stand alone psu too because it delivers 60 amps of 12v.I Like to use the - 7_22_2012_8_22_34_pm.jpg
have fun.
Posted on Jul 22, 2012
  • Rat 9
    Rat 9 Nov 02, 2012
    The one i uploaded was from my search and does not actually work. this one i made myself and does work.
  • Ray Samples
    Good luck !
I tried that on same model with but no go
just the fans that runs all the time
any other pinouts that might work
thanks
Posted on Jul 31, 2012
4 Suggested Answers
gripfitter
  • 557 Answers
SOURCE: Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
Posted on Dec 20, 2009
JaxPlanet
  • 922 Answers
SOURCE: Dell ATX(12v) power supply
The fact that it is made by Dell is irrelivent.
ATX is a standard and so are 20 and 24 pin motheroboard connectors.
You should find what you need by searching for: power supply unit on Wikipedia and Google.
Posted on Apr 08, 2010
  • 902 Answers
SOURCE: Dell DPS-1200EB A REV :01 I need to know which
1st of all thats INGENIOUS please let me know if it works. 2nd here is a image lilb86_0.jpg
Posted on Mar 22, 2011
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
How do i reset the power supply on my poweredge 2600?
Resetting the power supplies isn't necessary. Once one of the ptwo power supplies fails, the second power supply automatically takes over. Also, there isn't a need to power down the system to change the supplies as long as you change them one at a time.
Oct 12, 2010 | Dell PowerEdge 2600 Server
Dell poweredge 2600 server recently display a message " No boot device available Press F1 to reboot or F2 to setup" Please why?
Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
Aug 03, 2010 | Dell PowerEdge 2600 Server
No power to dell poweredge 1600sc. Redundant power supplies have no lights.
Either the power supplies have both failed, which is unlikely, or they are not connected to a hot outlet. Frequently servers are connected to uninterruptible power supplies (UPS) instead of being connected directly to a wall outlet. Make sure the UPS is on and functioning.
Dell provides lifetime phone support for their servers so you should give them a call if you need more help tracking down the problem. (800) 945-3355
If this helps please vote for my solution.
Feb 12, 2010 | Dell PowerEdge 1600SC Server
Which scsi connection do I use to connect internal
Normally you SCSCI cable has 4 to 7 connectors the ribbon cable normally the last or next to last for a terminator is installed on the end of cable most DAT drive are self terminating so you may need to remove the terminator off the end cable.
The power from the power supply 4 pins to tape drive I assume you are talking about the DAT drive
When dealing with servers with SCSCI you have 7 devices per channel on the back side of the hard drive backplane you will be able to add the DAT drive cable or a standalone controller 68 pin ‘
Let me know if you need more help I can post some photos where two of my servers have DAT drive installed one for a Adaptec control and the other using controller of the back plane of hard drive array.
Dealing with SCSCI maters not what contoler you use
Dec 04, 2009 | Dell PowerEdge 2600 Server
Power edge 1800 bought october 2006. It does have a DELL 650 Watt non-redundant power supply, type nr. PS-5651-1. Can I replace it with a standard ATX power supply, or is the connector not standard wired...
Dell uses proprietary psu's. You will need to contact them for replacement psu or find a supplier that makes psu's that can be used as a Dell replacement. Hope this helps.
Jul 07, 2009 | Dell PowerEdge 1800 Server
Poweredge 2600 power supplies in red
Possibly a power distribution board problem.
PDB requires replacement.
Jul 09, 2008 | Dell PowerEdge 2600 Server
Dell NPS730AB 730Watt Power Supply Logo
2,789 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
