HP printer problem, Oxc19a003 error ... new printer, just installed the 1st replacement cartridge recieved the error listed above
Beni S-P
  • 1006 Answers
SOURCE: HP PSC 1610V Printer
Here u have :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=390328&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Oct 12, 2007
SOURCE: cannot get the printer to accept the new HP black cartridge
On my officejet 5510, I decided that the printer was toast and decided to throw it out and buy a new one. After making that decision, I decided to pound on top of it it a few times. Guess what??? You guessed it.....it reset itself and started back working. That was about 6 weeks ago and I haven't had a problem since. I have since turned it off and on many times, and it works like a charm. GO FIGURE!! (I only recommend this to those who have given up and are planning to trash it anyway).
Posted on Feb 04, 2008
SOURCE: 10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Posted on Feb 20, 2010
Daniel S
  • 4323 Answers
SOURCE: Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Posted on Jun 22, 2010
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
SOURCE: HP Officejet J4550 All -in-one printer has print cartridge error
I called HP and they told me that, when that message comes up, its usually a problem with the ink cartridge itself... mine was expired, so replacing it fixed the problem. The expiration date is on the front of the cartridge, so see if that helps
Posted on Sep 17, 2010
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Refilled my ink cartridges on hp 309g gets error message
Yes it does work on HP C309g-m if you place a cartridge one by one as follow:
1- open the cover
2- replace an original hp cartridge by the compatble non hp cartridge
3-unplug the printer
4- close the cover
5-plug printer back on
6- press ok to all messages
7-repeat from step 1 to 6 above for each new non hp cartridge
Et Voila.
Many Thanks
Oct 09, 2012 | HP Photosmart Premium C309g multifunction...
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, go to this site for HP support (http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?locale=en_US&prodTypeId=18972&prodSeriesId=238800) .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
If the error does not clear, contact HP support. reference site:http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389#A3
Another option would be: 1. Open the top cover, remove
the print cartridge, and
reinstall it.
2. Install a new HP print
cartridge.
3. Check the connection
between the
DC controller PCA
(location J97) and the
memory chip on the print
cartridge (location J600).
4. Replace the memory chip
cable and contact assembly.
5. Replace the
DC controller PCA.
kindly read this forum 1st:http://www.fixyourownprinter.com/forums/printer/35236
Aug 26, 2011 | HP LaserJet P3005 Printer
Printer carriage stuck?
To fix cartridge errors, complete the following steps:
  1. Remove both cartridges (even if the message indicates only one cartridge). See your printer's manual or help files for specific information on removing and inserting cartridges. Most HP printers must be turned on to remove the cartridges. WARNING: Make sure to complete the procedure and reinstall the cartridges within 30 minutes. The ink in the cartridges can dry in the nozzles if the cartridge is outside of the printer for too long.
  2. Unplug the printer.
  3. Inspect the cartridges:
      If the cartridges are new, make sure the protective tape has been removed completely.Make sure the cartridges are not damaged. If the copper-colored electrical strip is torn or punctured, the cartridge must be replaced.Make sure the cartridges are compatible with the printer. See the manual for a list of compatible cartridges.
  4. Reinstall the cartridges. NOTE: HP cannot guarantee the quality or reliability of refilled or remanufactured cartridges.
      Make sure each cartridge is in the correct slot.Make sure the cartridge is snapped into place and the latch is closed.Close the front cover and plug the printer back in.
  5. If the steps above do not fix the problem, follow the procedure below to clean the cartridge and electrical contacts:
    1. Gather cleaning supplies:
        Clean distilled water. Use bottled or filtered water if distilled water is not available.Clean cotton swabs or any soft, lint-free material (coffee filters work well).
    2. Remove both cartridges.
    3. Unplug the printer.
    4. Lightly moisten the lint-free cleaning material with clean water.
    5. Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty. Figure 1: Cartridge nozzles and contactsc00059236.gif 1 - Nozzles 2 - Contacts Figure 2: Cartridge nozzles and contactsc00059237.gif 1 - Nozzles 2 - ContactsIf your cartridge doesn't look exactly like one of the illustrations above, locate the contacts by looking for an area with a number of small copper squares. The illustration below shows some representative cartridge contacts. Figure 3: Cartridge contactsc00059238.jpg
    6. Using a new swab, clean the cartridge contacts inside the printer (the print carriage). The illustrations below show contact locations for some representative carriages. If your carriage does not look like either of the pictures below, try to locate copper contacts inside of the printer that would touch the contacts on the cartridge when the cartridge is installed. Figure 4: Carriage contactsc00059239.gif Figure 5: Carriage contactsc00059240.gif
    7. Allow all the contacts to dry for at least five minutes, or dry them with a clean swab, then reinstall the cartridges.
    8. Close the front cover and plug the printer back in.
  6. If the steps above have not solved the problem, repeat them.
  7. If the error still occurs after repeating all the steps, replace the cartridges. If you have already replaced the cartridges once without solving the problem, contact HP. The printer might need to be serviced.
Jul 03, 2010 | HP DeskJet 5650 InkJet Printer
Hi
Daniel Scott
Jun 22, 2010 | HP Photosmart C3180 All-In-One InkJet...
Error: Oxc19a003 Printer wont print. Keeps coming up with this error
its the error with the ink cartridges, try to use new cartridges but if it doesn't gets resolved then its the problem with the memory of the printer which cannot be fixed... In 99% of cases these error doesn't go eevn after changing the cartridges as well
Nov 10, 2009 | HP Photosmart C7180 All-In-One InkJet...
Same problem, being told to replace the left cartridge. Authentic ink, 3 replacements, cleaned with distilled water and cotton and HP no help at all. Won't even give me to a supervisor!
Bad news. Try This.
  1. Remove all Ink cartridges.
  2. Turn printer off.
  3. Disconnect from computer.
  4. Remove power cord from Printer.
  5. Wait 3 minutes Plug printer power cable in.
  6. Start printer.
  7. Install left cartridge 1st. then rest of ink.
  8. If no errors plug computer cable in.
Should solve problem if it does not your cartridge recension chip in printer is more than likely faulty. have to have repaired.
Mar 08, 2009 | HP Officejet J5780 All-In-One InkJet...
HP LaserJet 5000n - Paper jam under the cartridge
Check the tray to make sure the paper stops are set right and that the printer is set for the correct size paper. Clean the feed rollers above the paper in the tray and if necessary, replace them.
Jan 03, 2009 | HP LaserJet 5000n Printer
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
REPLACING INK CARTRIDGS
For HP 5510 series for replacing the cartige, you need to lift the door just above the paper tray. Pull out the old cartidge, hold it so you can see the way it is inserted and click in gently in the same way.
Nov 19, 2007 | HP Officejet 5510 All-In-One Thermal...
509 people viewed this question
k24674
jasbo
jasbo
