Question about True GDM-47 Refrigerator
Where is the ballast for the lights located in a GDM 47 refigerator?
3 Suggested Answers
  • 7 Answers
SOURCE: I need to replace the ballast on my GDM 12 freezer
The ballast is located on the bottom inside wall where the compressor is located. Its usaually mounted, and can be easily removed and replaced. The ballast is rectangular in shape and has a few wires protruding from each end. To replace simply dismount the bad ballast and clip the wires. Match the ballast to a new one, reattach the wires using wire nuts, and remount ballast.
Posted on Aug 13, 2009
bobicehouse
  • 1524 Answers
SOURCE: Where is/are the ballast located for the two
http://www.truemfg.com/pdf/InstallManuals/GDM-3/gdm-3_english.pdf
Posted on Jul 25, 2010
What size light bulb for a GDM 12 coke fridge
  • Safety shielded fluorescent interior lighting.
  • Cabinet lighting utilizes electronic ballast and T-8 bulbs for brighter illumination, longer bulb life and increased energy
  • Remove yours and take to THD or Lowe's. Could call first; make have to go to specialty lighting store if not available at the DIY stores.
    Mar 05, 2014 | True GDM-12 Refrigerator Commercial
    Lights not working, and can't find the ballast location
    The ballast is located down by the compressor if you take off the cover the ventilation slats. Then in the very center where there is a plug from the compressor plugged into the side of the center support as a cover on the front of that open the cover and inside you'll find The ballast.
    Mar 09, 2013 | True GDM-69 Refrigerator
    GDM-49
    http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
    Go to the above web site. It should be the installation manual for your unit. It has lots of good stuff.
    Hope this helps
    Nov 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
    I need to replace the ballast on my GDM 12 freezer and I need to know where the balast is located
    Jul 24, 2009 | True GDM-12 Refrigerator Commercial
    Both lights went out at same time , replaced them still doesn't work .. Is it a Fuse ?? Where is the fuse box ?
    Bad ballast. Located in the frame work under the door.Take off the panel to access it.
    Jul 14, 2009 | True GDM-69 Refrigerator
    Interior Lighting on True Refrigerator Unit
    A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
    Jul 24, 2008 | True GDM-9 Beverage Cooler
    Ballast location?
    the ballast is right in the middle. you should see an electrical cord. open the 2 screws from the ballast cover. then unscrew the top and bottom screw from the ballast. the ballast should come off. cut the wires closer to the ballast, so that you can identify the wire with the new ballast, which will have the same color scheme.
    Jun 17, 2008 | True GDM-41 Refrigerator
    Lighting problem
    front center section behind the lower panel you will need to remove the front bottom grill to get to it
    May 28, 2008 | True GDM-41 Refrigerator
    True GDM-47 Refrigerator Logo
    194 people viewed this question
    Top True Refrigerators Experts
    Dennis Boxerman
    John Tripp
    John Tripp
    Are you a True Refrigerator Expert? Answer questions, earn points and help others
