Question about Oregon Scientific BPW129 Wrist Type Blood Pressure Monitor
Can you reset one of these units.i was at the doctors today and as i thought my unit is running high.i am looking for a reset button but i can not find one Thanks for the help.I did put in a new set of batteries.
    Brigadier General:
  • 4,736 Answers
Bruce, I think what you want to have done is have the unit re-calibrated. Only the manufacturer can do that. Below is a link to their contact information via email. In the Question/Category click on Product Technical Support and fill out the rest of the form.
http://www.oregonscientific.com/afterSales_contactUs.asp
Hope this gets you the help you need.
Posted on Mar 15, 2011
Haier window unit reset plug not resetting
check the house power board circuit breaker if the light indicator is not working
Jul 25, 2016 | Haier Heating & Cooling
Our Rheem Classic Air Conditioner Unit keeps tripping the reset button or something and we have to run out and trip it. Well today it won't turn back on.
What's probably happened is that your outdoor unit has overheated due to a high pressure/high temp situation. The reset button at the base of the o.d. unit is a HIGH PRESSURE RESET. This safety is factory installed to prevent the unit from operating under an excessive(per design) pressure.
•The o.d. coil needs to be cleaned
•The o.d. fan motor needs to be replaced
•The run capacitor(s) at the o.d. unit need to be replaced
•There is a restriction in the refrigerant cycle
Its also possible that a component has faulted, along with a high pressure issue. 1 problem can cause another. The reset opening sometimes let's us know something is wrong and its time to repair the problem before it gets worse. Its hard to say what to do now. If it was still opening the pressure switch you could try washing the o.d. coil. Call a tech!
Jun 23, 2015 | Heating & Cooling
My remote quit working. There is no learn button to reset it. What can I do to get the unit & remote to "talk" again?
u don't say make/model, but the learning button ma be under the lens/cover for the light. take it off and take a look. good luck.
Mar 26, 2015 | Building Materials
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
Our dog chewed on some of the wires, which I've reattached before and had the thing work. This time they won't reconnect, though the unit itself can be run by pushing a button in the unit.
if this is a central unit and the button you refer to is on the outside condensing unit, the wiring is propbably not the issue, the manual reset button is generally a high pressure safety switch, when you reset it if it runs for a few minutes then shuts off again unit you can reset it, you probably need to wash your outdoor coil. (it may look clean from the outside and still be blocked from the inside) shut off the power, verify that power is off, remoave the top of the unit and wash with a hose from the inside of the coil to the outside, make sure you clean all ares of the coil, use the hose pressure to "push' any debris through the coil then rinse the outside, reassemble, let dry completely and then start the system
Jul 19, 2009 | Heating & Cooling
My outside air conditioner fan is not turning, but when I push the reset button it runs for a while and begins cooling? Then it stops turning and gets hot inside again? What could be the deal?? It was 112...
if the button your pushing is in the unit outside it is a manual reset for high head pressure this cuts off the unit to protect the compressor,you need to clean the coil .turn the unit off and gently push water through the coil in an up and down motion till water comes out clean see if that helps
Jun 26, 2009 | Ruud Central System Air Conditioner
Ruud heat pump outside fan
You may be right in looking at the motor. It uses a different speed on heat than cool. The heat cycle uses low speed, usually red. Some manufactures use blue (medium). Cool uses black, high speed. If you are confident, switch the low speed wire with the high speed and see if this changes anything. If the fan motor isn't the problem, check the other setting (cool) if the overload trips, you may need to look into a new capacitor or compressor, if so, you can install a hard start kit. these are start boosters, and are inexpensice, sometimes they will give another year out of the comp. but I've put them on and they have lasted 5 years.
Mar 15, 2008 | Heating & Cooling
Oregon Scientific BPW129 Wrist Type Blood Pressure Monitor Logo
158 people viewed this question
Top Oregon Scientific Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Oregon Scientific Health and Beauty Expert? Answer questions, earn points and help others
