Question about Indesit W 123 Front Load Washer
My indesit front loading wg1432 model washing machine wont do final spin at the end of each programe, the rest of the programe is fine, just when it comes to final spin the dial stops at this point
  • Indesit Master
  • 1,527 Answers
Hello it might not be draining enough water out it has to pump water out before it spins check the pump also the filter if it has 1 hope it helps
regards
shaun
Posted on Mar 14, 2011
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
Indesit IWB 5123 Washer Which program ends with the washing left in the final rinse water until spin cycle is selected
push in yourrince hold/or crease gaurd button if you have one. normall wollen cycles will stop.
Feb 16, 2010 | Indesit W 123 Front Load Washer
Indesit WDG1095W combined washer/dryer - program wheel stopped
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
http://www.4indesit.co.uk/cgi-bin/product.pl?PID=111846&query=Indesit%20WDG1095WG&model=WDG1095WG&path=52691
May 22, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
302 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
