Hi I am trying to print from the brother printer HL-2140 which I just added to my printer list. The file goes to the printer but status comes up as "stopped" I tried to pause and resume printing, when doing this the status flicks to "printing" and then back to "stopped". Could it be I have downloaded the wrong installer? I am also working from a MAC OS X 10.5.5. I look forward to hearing from you. Regards, Libby
  • 41 Answers
How to I change printer docs list from Hl 2140 brother to another printer which is working
All installed printers are on the drop down list when you press print from the menu under FILE, top left hand corner. Select the printer you require.
Feb 05, 2014 | Computers & Internet
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
Can i set the Brother HL-2140 to print double sided. I cannot find it ?
The Brother HL-2140 does not include duplex printing. The only option for double sided printing with this model is to print odd numbered pages, then manually replace the paper into the tray and print the even numbered pages in a second set.
Regards,
Dan
IT Professional
May 04, 2011 | Brother HL 2140 Laser Printer
I HAVE HL 2140 PRINTER. INSTALLED NEW TONER BUT NOT PRINTING GETTING WITH DRUM ERROR
It is possible that the drum needs replacing.
Print a lifetime status page, and see if it says "drum 0%". If so, replace the drum and RESET the counters by using the reset button combination.
Mar 14, 2011 | Brother HL 2140 Laser Printer
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
Oct 05, 2010 | Brother HL 2140 Laser Printer
Printer is on but will not print. Brother HL-2140 laser printer. The print log status reads = Error - Sent to printer.
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thanks,
Pat
Mar 29, 2010 | Brother HL 2140 Laser Printer
Brother HL-2140 printer driver problem - won't load
Uninstall the completly the printer driver form add and remove program and dissconect the printer cable and restart the computer. after that download the latest driver from herehttp://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/monolaserpri/hl2140_all.html?reg=us&c=us&lang=en&prod=hl2140_all and install it.
Nov 13, 2009 | Brother HL 2140 Laser Printer
HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Sep 30, 2009 | Brother HL 2140 Laser Printer
Trouble with pdf docs
If your pdf's are saved on your pc or mac and they print fine, then it is probably a problem with firewall or av. allowing printing from internet. Check PDF program settings for port number to exclude or accept in firewall or check firewall and add pdf program to list of exceptions.
Jun 24, 2009 | Brother HL 2140 Laser Printer
71 people viewed this question
k24674
jasbo
jasbo
