Question about Toys
Need to reassemble swing set after we moved - Toys
  • 2,632 Answers
Welcome to Fixya. Can you provide the make and the model so that we can check if there is an available manual online.
Thanks for using Fixya
Posted on Mar 14, 2011
Freezer was thawed out and now the door won't close
please check the way you installed shelves and the way food is stored. Remove food and shelf and reassemble. It should fix your problem.
Make sure the fridge level so front is raised so doors swings close after you had open them
Aug 26, 2014 | Refrigerators
HOW TO REMOVE FRONT PANEL OFF THE GATEWAY ESSENTIAL
  • Remove the side panel first to make the front bezel easier to access. To remove the side panel, remove the thumbscrew from the side panel cover. If the thumbscrew is very tight you may need to use a screwdriver to loosen it.
  • Lift up the release lever to loosen the side cover. Carefully swing the panel away from the computer and lift the panel away. Set the panel aside.
    Move the computer slightly forward on the desk so that the top and the bottom of the case are both accessible. Pull the bezel out and lift it free of the case. Set the front bezel aside until it is time to reassemble the unit.Read more: http://www.ehow.com/how_5775555_remove-panel-gateway-e_series-computer.html#ixzz2pxkABtPy
    Jan 04, 2014 | Gateway Computers & Internet
    My excavator hitachi ex200-1 weak swing and when you swing then stop vibration begin on turn table when i stop to swing,and when i swing and lift cylinder raise,vibration on the turn table will contin
    Not sure would need to have a good look ,but i suspect a safety valve isnt closing properly causing thumping within the hydraulic system which is the vibration you can feel,shouldnt cost a lot to repair providing the faulty valve can be located so return to the dealer as they will have a good idea as yours isnt the first to go wrong iam sure
    Sep 24, 2012 | Cars & Trucks
    Fisher price my little lamb baby swing will not swing
    If it makes a sound but doesn't swing then the metal rod inside the motor casing was probably bent. If it makes no sound then it could be several different problems.
    If it does make noise (my daughter did the same thing) then you can fix it, though it's not the easiest fix. Unplug it/remove batteries, and you'll need to remove the legs. Start removing screws to get to the motor casing, the first ones you'll need are in the battery compartment. Be careful as you're doing this, once you get the plastic casing off things can move around. Have someone as a second set of eyes if you need it.
    Once you can see the guts look for a thin metal stick, no thicker than a telephone cord. Yup, that's what moves the swing. The metal is easily stressed. You can carefully power it up if you want to see how it works or make sure that little thing is moving. There's a small gear underneath all that, but you don't need to get to it.
    Instead, you'll need to beef up that little stick. I used a leftover rubber gasket from a ceiling fan first, then I was so amazed it worked I took it back apart and used a longer piece of rubber tubing with a harder plastic tube over it (it's a very tight fit). It will still need to rock back and forth in it's little hole so don't go too crazy.
    The one drawback is that I think it has a louder operation now, but the one thing that both my kids adored with the swing was the rhythmic tick-tock. If baby is happy, mama is happy.
    Anyway, FP will sell you a whole new motor, or if you an find the exact part number you might be able to get a new pendulum. But I like fixing stuff, and I like free better, so if this is what yours needs I hope it helps. If this is but you don't follow what I've written I'm happy to try and take pictures of mine.
    Aug 30, 2012 | Fisher Price My Little Lamb Dreamy Motions...
    I can't figure out how to switch from position 1 to position 2.
    U have to grab the bar and like pull out and move it back and forth between positions. If your sitting in front of the swing(chid facing you) grab bar and pull away from you and move seat. Might have to hold the little side thing that says one and two to keep it still.
    Mar 31, 2012 | Cosco Juvenile Cosco Sway n Play Swing...
    Swing flap not working
    Remove cover check cogs attached to motor and check if motor is moving when set to swing
    Nov 23, 2011 | Heating & Cooling
    The swing barely moves even on highest setting
    If you have a bigger baby, the weight can affect how much the swing can move.
    Nov 10, 2009 | Baby Gear
    I was given a Whirlpool ET1FTK 20.8 cu ft refrigerator/freezer. Door frame going thru is 29 inches. Need to take off doors of fridge to get in house. Anything you can send me. Don't have any of the books...
    Start at the top and remove the hinge (5/16 socket). Slip the door off and remove the center hinge. Slip the lower door off and remove the lower hinge. Now is the time to reverse the door swing if it needs it. Move the handles to the other side and reassemble with hinges on the other side if you do.
    Eric
    Nov 03, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
    Baby swing......graco doesn't swing
    I had the exact same problem the motor worked fine but when we took it apart the gear inside was stripped. i hate saying it but best thing you can do is buy a new swing. i personally recommend http://www.toysrus.com/product/index.jsp?productId=3420749&camp=PPC%3A204318389. its a little bit high but so worth the money. my 8mo old baby girl loves it. it also has a AC adapter so no more batteries and an ipod hook up as well so you can pick what music you want your baby to listen to. best of luck.
    Mar 29, 2009 | Baby Gear
    Toys Logo
    37 people viewed this question
    Top Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Toy Expert? Answer questions, earn points and help others
