Question about Evesham Computers & Internet
I cant clean install or run win xp from c drive.or from cd rom using win.repair console ' specified drive is not valid/there is no disk in the drive'? when i type in fixboot in command prompt.. i have tried many other 'command prompts ' eg CHKDSK, 'BOOTCFG WITH ALL ITS SUB TEXTS, but get the reply 'failed to scan disks may be caused by corrupt file system could you please suggest possible solutions or do i need to replace the hard drive
  • 81 Answers
If the repair console cannot find the c:\ drive then yes the hard drive is done. Before you trash it though I suggest using an Ubuntu Linux Live CD to see if you can rescue your files.
Posted on Mar 14, 2011
  • kingworcs Mar 18, 2011
    I used Selkie - a bit costly but saved a huge photo library which had not been backed up. Bit expensive but worth it. Once content copied to another external hard drive was able to restore as it was no longer necessary to keep data on hard drive.
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
My sony laptop with windows xp home media center keeps rebooting
When XP gets into the rebooting mode, you will have to run a chkdsk or do an XP repair. You will not lose your data. But you do need your recovery cd or a WinXP cd.
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type chkdsk C: /R at the prompt in the recovery console.
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
Lastly, your drive can be taken out of the unit and set into an enclosure or adapter. The data can be saved, the your hard drive can be formatted and programs and data reinstalled.
Good Luck,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 10, 2009 | Sony VAIO VGN-NR120E/S Notebook
Lap top dell inspiron 6400, cant get into windows,
Have you tried doing a winXP repair:
XP repair
When you boot with the Dell Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If the repair does not fix it :
If you have documents you need,you would have to set the hard drive in an enclosure and copy the files over. Then you can run the Dell recovery disk . This will set it up as when it came from Dell.
Thanks, Joe
Feb 22, 2009 | Dell Inspiron 6400 Notebook
AVG 7 detecdted Virus Hurri on partition table. How do I remove ?
You will need to fix the master boot record with the Windows XP Recovery Console. To do this, you will need a Windows XP install CD.
Here are the steps to use the recovery console:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
  4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
In this instance, the correct commands are:
c:\fixmbr
c:\fixboot
The type exit after finishing then remove the Original OS CD.
The machine will reboot properly.
This will fix your boot sector
And All should be well
Dec 28, 2008 | Microsoft Windows 98 for PC
Hard drive failure
Hi, you have nothing to type there. You mean you have chosen the 1st section that opens recovery console,right? not that one. You should see the Terms of Agreement in your WinXP cd first, press F8. A section containing to install a Windows XP appears, Press Enter. Then that's the time it will search for your previous Win xp installation. In will then let you choose whether you will install a fresh copy of WinXP OR to Repair it. Choose the Repair. It will automatically repairs and format your Harddisk without deleting your files in it.  IF there's no Option to repair it, that's the time you will have to go to Recovery Console.
  • To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
If still you cannot get through to that, drop me a comment again and tell me what you have done. Feel free to ask me.
Dec 27, 2008 | Computers & Internet
No OS FOUND on my Pavilion a1600n (preinstalled Win XP) can I install Win XP Home Edition I bought. My recovery disk will not work.
boot with win xp setup disk.
set first boot devic as cd drive then insert win xp disk into it.
then follow wthe procedure .try to repair os win xp .if it is not found bye setup go to recovery console run this command: CHKDSK /r
then wait untill cmd probmpt.
ten u can repair win xp
Sep 15, 2008 | Computers & Internet
Blue screen
According to the Microsoft Help and Support
CAUSE loadTOCNode(1, 'cause'); This issue may occur if your CD-ROM is failing or is not supported.
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue: 1. Make sure that your Windows 2000 CD-ROM is clean and is not scratched. 2. If you have more than one CD-ROM drive, run Windows 2000 Setup from the other drive. 3. If these steps do not resolve the issue, you may have to replace your CD-ROM drive.
Jul 04, 2008 | Dell Dimension 1100 PC Desktop
Win xp prof. again &again re starting problum
if the system was able to enter the desktop and restarts...once possible cause is a virus...scan the pc via safemode or reinstall windows.
but if it didn't enter the OS desktop...cause might be the boot loader or MBR is damage..
worth a try:
Run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
5. At the command prompt, type this commands one at a time.
FIXMBR C:
FIXBOOT C:
COPY [CDDRIVE]:\I386\NTLDR C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM C:\
BOOTCFG /rebuild
6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Nov 19, 2007 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
