Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
I am replacing a lamp in my tv that went out.I ordered the lamp and now I cannot get it to work. Can you help me?
  • Hitachi Master
  • 8,457 Answers
Tv turn on now?The tv now having alot of clicking sounds too?Yes,the board that call the Ballast board it is also dead.This Ballast board only job are to ignite the tv projection lamp.Must replace the Ballast board too.
Posted on Mar 14, 2011
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
When I turn the tv on it came on for a minute then started flashing on and off then went blank but the power light keep flashing off and on with a blank screen.
This problem is easy to repair. If when you turned the tv on and it had sound and picture for a second or two, and the power went off and the power green light keeps flashing on and off, it is a bad CCFL backlight lamp inside the LCD panel which has 10 of these lamps in it, but only one is bad. Replace the lamp and the tv will power on. What the tv is doing is, it has stored a lamp error code on the main board and turning the power off. The replacement lamp is part # RLMPLA029WJN1 and you can buy them at www.encompassparts.com for $19.49 ea. Go to their web sight and sign in as guess to order. I can give you step to step instruction on how to check how many lamps you will have to order if you need me, too. You will have to take the tv apart to check them.
Aug 03, 2011 | Sharp LC-32SB23U 32 in. LCD TV
I have a Sony tv KDF50WE655, the other day while I was watching tv, heard a noise and the tv went off, displying the lamp red light..I ordered and replaced the lamp. I made sure the lamp is ok and the door...
Please make sure lamp cover is fixed properly in its position after lamp replacement as it has to press a safety switch located nearby lamp cover.
3 times red blink problem is related with that lamp cover safety switch only.
Hope this will help.
Thanks.
May 27, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
One year to the date television stopped working ,,, tv would start blinking and could hear but not see
This happened to me also. I just made the deadline to receive a replacement lamp from Vivitek by 2 days, because of the warranty. If not, I would have had to pay $250. This happened in 2009. My replacement went out in Dec, 2010 and I can't find a replacement anywhere. Order a new lamp, hope this works.
Feb 21, 2011 | Vivitek V37655 56" DLP TV
I have a Mitsubishi diamond WD-62725 the lamp light was on so i ordered a new replacement for it I installed the new lamp and the picture looks brighter than ever remember seeing it but the lamp light is...
we have the same brand tv but the 65" model. had a 4 year warranty just in case the lamps went out. the lamp went out and we called conn's to come out and fix the tv. the repairman replaced the lamp, and then he said to unplug the tv from the wall or the strip it is plugged into and wait 5 minutes and then plug it back in. he left and said to call him back if that did not work. did what he said and it fixed the problem. try unplugging the tv for 5 minutes and plug it back in and see if that might take care of your problem.
Jun 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
My screen went blank and the 3 lights on the front of the tv were flashing (lamp/temp). I ordered, received, and replaced lamp as I had done previously with this problem. The tv worked beautifully for...
Hi,do you hear any strange noises? if you heart clicking or like wanting to turn on it could be the ballast that's the board that powers the lamp.Do you hear buzzing,whirling,or high pitch sounds?If you do it could be the color wheel which is a little disc looking that when the light of the lamp goes through it creates the colors on the tv.This are the most common failures on samsungs.
Sep 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
Sony KF-50XBR-800Replacement Lamp blew after 1 minute
Although this is rare, the problem is the lamp driver board, commonly called the ballast board. Follow the leads back from the lamp an you will find a smallish rectangular board with one large connector and one small one (besides the two wires going to the lamp). If you feel confident, they can be ordered from a Sony parts distributor such as Vance Baldwin or Union Electronics Distributor for about $115 - $150
www.ued.net
Just search under the parts for "Sony" "ballast" and the model number of your TV. Or just call them at their 1-800 number.
If you dont feel confident, you can have a shop repair it for about $450
Mar 20, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Lamps
color wheel brakes then causes this same affects check your wheel
Nov 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
