Question about Garmin Nuvi 1350T
The Garmin 1350 will start up (garmin screen appears) then says loading maps. Right after that it dies.
This is weard sounding, I know, but it worked on my "non working" unit.....
On another forum it sayed to "hold your left thumb on the top left part of the screen, while you power the unit up from a USB power cable from a computer" and continues.... 'you must continue to hold your thumb on the screen until the linked icon shows up on the screen" After that let the unit charge for a while.
I did not try powering up whith my thumb on the top left part of the screen while in the car but hey... give it a try...
Hope this helps!
Posted on Mar 17, 2011
  • Dunkiedoo Apr 01, 2011
    Addendum: You absolutely MUST use the supplied garmin cable.... no subs will work. A substitute cable will put the gps into data mode and lock the screen.
    Duncan
I bought this devise in USA last year where it worked very well.I fished it out the other day but it doesn't work here why?
When you mean does not work, does the unit power up or is it plain dead? If it does not turn on, then you will need to troubleshoot or send out for repair.
If it turns on, but does not provide you with maps, you need to load maps for Australia as you currently have US maps loaded on the device.
Google search for Australia maps for your unit, or contact Garmin customer service.
Mar 26, 2015 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350 map cannot update
may have to download plugin, garmin communicator off my.garmin.com
Nov 06, 2013 | Garmin nuvi 1350 Car GPS Receiver
Garmin Nuvi 1350LMT Nuvi 1350 W map update error
Run the Garmin WebUpdater once more and apply any updates. Consider downloading and installing the lifetime map update to the computer and then use the Garmin Mapquest or Basecamp computer program to send the map data to the nuvi. Overall, it takes a little longer, but is better than trying to download directly to the GPS itself. If you're not having luck, it will probably be wise to contact Garmin Tech Support. It would be wise to mention the funky "once / month" GPS reboot issue with Garmin at this time too.
May 10, 2012 | Garmin Nuvi 1350LMT
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
I hope that helps.
Garmin starts loading maps, then screen goes blank
First do the master reset -Hold down finger in lower right corner of screen and press switch on button. Hold still until asking of erasing all private data appears. FAST click on YES.
If it doesnt work:
From www.garmin.com -cllick on SUPPORT -> SOFTWARE
Get webupdater and install it. Run it and you'll find button "Find device". Of course you can't because it does restart all the time.
Hold down finger in UPPER LEFT corner of screen and press switch on button. Hold still for about 10 seconds (GARMIN appears and nothing more) and fast connect the USB.
HOLD switch until icon of connected computer appears on the screen. After then device stops resetting.
Webupdater can find your device, and now you can put a new firmware by doing step by step instructions from webupdater.
wildadam
Jun 19, 2010 | Garmin nuvi 1350 Car GPS Receiver
Reloading map Screen blank
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 04, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
Garmin Nuvi 1350T Logo
80 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
