I have a copy of an excel file but have no idea where the digital copy was put. I have the first term in A1, the whole first lise and the create date. Please help me find it. I have put the first term on the Windows 2007 search but cannot not find it that way.
  • Jess Ayers Mar 17, 2011
    That is what I did. Still can't find it.
    Good precaution in suggesting 'be sure it's on this computer'. I've thought about it. This file was created in Feb and I had access to no other computer.
    President:
  • 2,047 Answers
First thing to do is ensure that the digital copy is on the same PC which you are using. Once this is established then depending on the windows which you run simply go to the start option which usually is the microsoft circle at the left hand side of your screen or simply press the microsoft button on the keyboard usually the third from the left between FN and ALT keys.
Next type the create date or any of the contents of the file in the run/search bar which can be found at the bottom of the pop-up. The same place used for running commands. All files created on the said date will be displayed or containing the typed phrase will be displayed.
Hope this solution has been helpful?
Posted on Mar 14, 2011
Corrupt excel 2010 file
1 - Using "Open and repair"
Microsoft Excel has a built-in repair tool for corrupted files. To access it, go to File and Open. A menu will pop up in which you'll have to select the file you want to fix and then choose "Open and repair" from the dropdown menu. This will open a dialogue box in which you can pick between the repair option (which will recover as much information as possible) and the extract option (that will copy values and formulas). The two alternatives combined should work fine to save your work.
2 - Saving the file to a different format
If you can open the file but you can't modify it or save the changes, you should use this method. You'll have to save the file to a different format (such as SYLK or HTML) via the "Save as" menu. Once you've done this, you'll have to open the recently saved file and then save it once again (but this time, you'll have to choose the Excel Workbook as the format). By doing this, you'll be creating a fresh new file with all the data from the corrupted file.
3 - Opening the file in Microsoft Word
This option is only available for the people that have the Microsoft Excel converter installed on their PC (it can be downloaded from the Microsoft website). You simply have to open the corrupted Excel file with Word. However, you should know that this method only works for retrieving data (all the structures from the sheet will be gone, such as formulas and macros).
4 - Altering the Calculation option
If your file isn't opening at all you can try to adjust the calculation option. Simply open Excel in a blank workbook, go to the "Tools" menu and look for "Options". There you'll find the "Calculation" tab in which you'll have to look for the "Calculation" section and set it to "Manual". Click OK and then try to open the corrupted file once again.
5 - Linking the corrupted file
In this method, you'll have to link one cell of a blank worksheet to the corrupted workbook. Be sure to create the new worksheet in the same location as the corrupted file. Once you've done this go to the blank worksheet and enter the following in the A1 cell: <Filename>!A1. This will copy the data from the A1 cell of the corrupted file to the new sheet. In case it works, simply click "Edit" on the cell and select an area like the one covers the cell that contain data in the damaged file, and then click Paste. Then (and with the cells still selected) click Copy on the Edit menu.
Jan 23, 2013 | Western Digital Corporation WD ShareSpace...
I do not know how to mark tallies on excel?can you help please?
The process is slightly complicated ...
1. You need to install a FONT which supports tally marks...
You can get one from http://www.subtangent.com/maths/resources/tally.zip
Download the zip file and extract the ttf file and put in C:\Windows
2. Now you need to convert your numbers like this
1 to 1
6 to 51
7 to 52
11 to 551
and so on
which you can do using a formula like
=REPT(5,INT(A1/5))&MOD(A1,5)
in cell B1 with your number in A1
Now put this in C1
=B1
Copy the formulas in B1 & C1 down if you many numbers...
Now choose the TALLY FONT for Column C
That is all... :-) Good luck..
It's little complicated but let me know if you can't solve with this.. I am doing a research on this..
Apr 29, 2010 | Computers & Internet
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
Aug 30, 2009 | Olympus VN-4100PC Digital Voice Recorder
Using excel to solve problem by trial and error method
In A1, put a random value of d as 0.1. Then in B1, put your equation 5*d^4 - 10.29*d^(-1.333), wherein refer d as A1. Then use goal seek function on Tools Menu. First "Set cell" as B1, "To value" as 0.124 and "By Changing Cell" as A1. Excel will do the Trial & Error and will give you the answer in Cell A1.
Nilesh
Mar 31, 2009 | Microsoft EXCEL 2004 for Mac
Invoice & Order Minimize Data Entry - Especially Name and Address
Do you have Microsoft Access? If so, you could use that to create a database and an invoice form. You could also use Access to "dump" the info into Excel to track and record.
Otherwise, try searching for "Import Data" in the Excel help. It would be very difficult to walk you through the whole process, but if you have specific questions about certain steps, that would be more manageable.
Jan 06, 2009 | Microsoft Excel for PC
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
Excel formulas
hello
yes it is.
example
sheet1
A1 (50)
A2 (50)
sheet2
(A1)=
"=Sheet1!A2+Sheet1!A1" <-this is the actually code in sheet2 column A1
ok let me explain
in A1 and A2 in sheet1 you got 50 and 50 like numbers.
in A1 on Sheet2 you have = sheet1 a1 + sheet1 a2.
did you get it?
dont know else how I should explain it...
good luck
Oct 09, 2008 | Microsoft Excel for PC
Excel formula
I'm assuming you'd like to assign a numerical value to cardinal references (1st, 2nd, 3rd, 4th, etc.).
Best way to do this is to create a quick lookup table on a separate sheet of the same .xls document. Down at the bottom of the page, click on Sheet2 and create a quick table where column A has 1st, 2nd, 3rd, etc. and column B has your values.
Now click back to Sheet1 where your data is and in A2 put this formula:
=VLookup(A1, Sheet2!$A$1:$B$x, 2, FALSE)
Note: replace the lower case x in the formula above with the number of the last row of data in your lookup table on Sheet2.
You can copy and paste this formula down the column to calculate your other values.
Hope that helps!
Terry
Aug 30, 2008 | Microsoft Excel for PC
Computer
Any formula in Excel starts with the equals sign ("="). This is how Excel distinguishes between formulas and literal values. Knowing this, you can create lots of formulas using the usual operators of +, -, * and / for addition, subtraction, multiplication and division, respectively. Please see the examples below.
Add 1 + 1: =1+1
Add the contents of cell A1 to the contents of cell B1: =A1+B1
Subtract 2 - 1: =2-1
Add the contents of cell A1 from the contents of cell B1: =B1-A1
Multiply 1 times 2: =1*2
Multiply the contents of cell A1 times the contents of cell B1: =A1*B1
I hope this resolves the question. If not, please let me know.
Aug 08, 2008 | Microsoft Computers & Internet
Populate a cell based on a specific criteria in Excel
[formula in the new Category Column]
=RIGHT(A1,LEN(A1)-SEARCH(" ",A1,LEN(A1)-11))
Where A1 is the cell that stores the Business names.
May 20, 2008 | Microsoft Excel for PC
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
