I have dsl by embarq and want to move my desktop pc into a room with no phone line.
    Problem Solver:
  • 18 Answers
There's three options you can consider:
1) Stick with a wired connection. If you're just moving the PC to an adjacent room, you can buy a longer ethernet cable. I have a 25-foot cable myself, and you can potentially find them up to 100-foot long. Of course, this can be a trip hazard, so if you go this route, take appropriate safety precautions! This also might not be a good idea if you have pets or small children who can play with or get tangled in the wires.
2) Move to a wireless connection. This will probably be more of an investment for you. First, your desktop needs to have a some way to communicate wirelessly, which it might not have. You can figure this out by checking the Network Connections in your Control Panel. If your PC doesn't have wireless, you can buy a network card or other solution from Best Buy.
If it does, then you can move on to the wireless router. These are common, you can find them at Walmart for about $50. Once you unpack it, refer to the user guide for installation instructions. Do not move your desktop until after you have set up your wireless router. You need a wired connection for setup. Also keep in mind that wireless has a maximum range, and can be affected by signal interference and physical barriers (walls, etc).
3) Have the phone company install another port in the new room. This is probably the most expensive option by far, so I would only suggest it if the above two won't work for you for whatever reason.
Posted on Mar 14, 2011
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
Aug 18, 2011 | Computers & Internet
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
6 Months with Embarq - No bandwidth at night
when u get dsl that means bandwidth is not guaranteed. 1.5Mbps is the maximum theoretical bandwidth. You can't expect more than that. DSL is a shared network. So if you want to get dedicated bandwidth you have to go to other technologies like leased lines :) . They can't do anything. MTS can never be achived in practice.
Jun 15, 2009 | Dell Microsoft Windows XP Home Edition
I HAVE A LAPTOP AND TWO REGULAR COMPUTERS.I RECEIVED A DSL MODEM FROM EMBARQ.I PURCHASED 2 USB ADAPTERS N MY SISTER GAVE ME HER WIRELESS ROUTER BECAUSE SHE NO LONGER USES IT.THE ADAPTERS AND ROUTER ARE...
Hello JAZZYBELINDA,
I read your post and wanted to know if you are able to access the internet if you connect the modem directly to one of your computers. I would like to make sure that we do not have a problem with the network. What errors are you seeing and what lights do you see on the modem and router? Please send your phone number via email or private message and I will review the network for you. Thank you for giving us the opportunity to help you.
Lamont L.
Embarq Customer Outreach
embarq_lamont@embarq.com
For additional support please visit www.embarq.com/rescueit or call 1-877-646-3282
Voice | Data | Internet | Wireless | Entertainment
Sep 10, 2008 | Belkin Computers & Internet
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Embarq online security is causing a problem with my Quickbooks programs it says the security system is interfering with ActiveX controls.
Hello cncurfman,
After reading your issue, I would recommend you contact our RescuIT team at 866-626-8154 or visit their www.embarq.com/rescueit page for more information. This is a team that can support pc concerns with conflicting software.
Thank you for using Embarq, your complete communications solution.
Lamont L.
Embarq Customer Support
For additional support please visit www.embarq.com/freetv or call 1-877-646-3282
Aug 11, 2008 | Computers & Internet
Embarq internet
No you can just move it and plug it in.
Jul 11, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
