Question about Philips Televison & Video
Television -only have Sky reception - won't turn on. It will re-set after a while if we completely disconnect the power but then it switches itself off again after about an hour.rold,
  • Philips Master
  • 8,457 Answers
Tv power supply board it is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 14, 2011
Get my Sky reception back
You may have to check or adjust the alignment of your sky dish.
Mar 02, 2015 | Televison & Video
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Baird tv
    Two things you can try:
    Check the remote control and press the button for Digital input. Someone may have set the tv to expect an analogue signal from the aerial while you were pouring your wine. Because the analogue tv signal has been switched off the tv won\'t be receiving anything off-air. It will need setting back to digital to receive Freeview.
    OR
    The television set may be dropping itself into "AV" mode and is expecting an input through a SCART or HDMI socket. Sometimes an external device (video or DVD player) will hijack the television if the set-up hs been configured for this. Try unplugging all external devices (Sky box, DVD, VCR, games console or whatever you have plugged in). Make sure that the telly is configured to digital input and tuned to BBC1. Then see if the it will show the programme.
    If the television is actually broke then you should return it if it\'s still under guarantee.
    Jul 15, 2013 | Televison & Video
    I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
    Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
    If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
    Hope this helps.
    Oct 21, 2010 | Televison & Video
    Hi, i have a pace sky digibox box switching itself off
    Well every time you switch off the power the digibox returns to the factory default settings. The power must be maintained to keep those settings. There may be another brand that has battery back up to maintain the selected channels. Check with your owners manual to see if yours does have that feature. It continues to draw a very tiny current as long as it is plugged into power. There is no solution except a battery back up or leave it plugged in all the time.
    Zashiban
    May 31, 2010 | Televison & Video
    How do you hook up the dvd player to the tv with a vcr hooked up to the tv
    Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    32PFL5232D/37
    The code is 0081 and this is how you do it.
    '4 digit' or 'Brand Set' method
    1. Turn on your TV.
    2. Press TV on your Sky remote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    4. Press TV on your Sky remote control again.
    5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
    If the light blinks once only, re check the code for your TV and start again at step 1.
    6. Press the on/off button (power-top right button on your Sky remote control).
    If your TV switched off, press select . The light on the Sky remote control blinks twice.
    If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
    If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
    7. Press TV guide .
    If you see the TV Guide screen, the remote control setup process is complete.
    If you did not see the TV Guide, you must now set the TV Guide function as follows:
    8. Press TV on your Sky remote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
    Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
    Sky code for remote
    The code for you sky remote is 0125.
    4 digit' method
    1. Turn on your TV.
    2. Press tv on your Sky remote control.
    4. Press tv on your Sky remote control again.
    5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
    If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
    7. Press tv guide .
    If you did not see the TV Guide,you must now set the TV Guide function as follows:
    8. Press tv on your Sky remote control.
    10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
    11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
    Feb 13, 2008 | Televison & Video
    How good is Sky HD on Le32r42b
    Hi
    I just got the sky hd and i have a 32" samsung tv and the reception is crystal clear would defo recommend it!!
    Nov 18, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
    High definition reception
    You should have 2 cables going into the Sky HD box not just 1
    Oct 31, 2007 | Toshiba 52WM48 52 in. HDTV-Ready...
    Televison & Video Logo
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
