Question about Yamaha RX-V459 Receiver
Can Yamaha RX-V459 setup as bi-wired? - Yamaha RX-V459 Receiver
    Brigadier General:
  • 8,546 Answers
No, why? It's more hype than actual improvement.
http://forums.audioholics.com/forums/archive/index.php/t-1223.html
Posted on Mar 14, 2011
Testimonial: "Thanks for your quick reply, Guru. :)"
My Yamaha RX-V459 amp will not turn on. Suggestions?
Check the fuse, it's possible to be blown. If you not deal with electronics, don't atempt to repair it ( first you need to know what cause the fuse blown, and after that you can change it) so, i sugest to call a service center.
Dec 09, 2017 | Yamaha Audio Players & Recorders
What's difference between Sony str d615 an Yamaha rx v459
You should be able to download the user manuals on both of these units for free by just googling them and then compare the stats.
Larry
Aug 14, 2015 | Yamaha Audio Players & Recorders
Yamaha Theatre receiver turns off at high volume 'Check SP wires' checked speaker wires no problem found. Why is this happening?
there are usually 2 things that cause this, (1) a driver in your speaker is going bad or a output IC/transister is going bad. Being a tech I have seen devices that operate fine at low to moderate levels but would fail when driven hard.
Feb 27, 2014 | Audio Players & Recorders
Hello i have a yamaha RX-v459, and i have an HDTV, can i connect my cable box to the yamaha and the yamaha to the TV and get HD? the Yamaha does not say HDTV, does that matter, or will i still get HD?
Yes, the cable box should/could be treated as any other digital audio device. The video could also be run directly to the TV as it doesn't actually improve from being routed to/through the Yamaha, does it?
The labeling on a given input is irrelevant (except for "PHONO", which is literal and exclusively for a turntable).
May 17, 2011 | Yamaha RX-V459 Receiver
I getting noise in yamaha rx-459 please help.
I used to get noise as well. It turned out to be that one of the cables to the speakers was loose. Try tightening the cable connections to the Yamaha and to the speakers.
Mar 01, 2011 | Yamaha RX-V459 Receiver
YAMAHA YDS-11 TO A RX-V459
Hi, as per yamaha site RX-V459 doesn't have the DOCK connector which is used by YDS-11 dock (or the bluetooth module). This is the only possibility to connect the YDS-11. YDS nor receiver don't have USB connector and they are not needed.
For example RX-V465 does have DOCK connector and supports YDS-11.
For your receiver, you can use only analog audio cable with your iPod.
Dec 17, 2009 | Yamaha RX-V459 Receiver
Vocals missing while playing with 2 speakers
Go to the amp "Basic Setup" and alter basic setup according to
- the size of the room (details in the manual)
- alter the no. of channels e.g. if you have only 2 front speakers, change the channels to 2.1 (.1 for the subwoof)
- Once the setup is changed, the amp pumps in sound according to the set up
All the best
Apr 25, 2008 | Yamaha RX-V459 Receiver
Yamaha RX-V459 Receiver Logo
349 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
