Question about Ranger RCI-2995DX Base Scanner
My signal meter is lazy, it will not go past 9on the meter,even if they are only out side the house.audio receive is very good. my radio is a ranger rci-2995dx, I can see the vr2 controls the ssb, but cant find the one for am-fm. thank you.
Adj VR1 next to VR2 they are in the center of the main motherboard. VR1 will allow you to adj the S meter in AM mode only.
Posted on Apr 21, 2011
  • Jeo8 Apr 26, 2011
    Hi I just did a repair on a 2995DX the meters are easy to re-align and you don't need any equipment to do it. Just a screw driver and you are set to go. Just do the following I did and my meter on both SSB and AM are now aligned to my other RCI radio. Just put your 29950DX next to another radio that has a good working meter and using an antenna switch back and forth between both radios. Use VR1 to adjust the AM singal to match your other good working radio. Use VR2 to adjust the SSB signal to your other good working radio. Find a good fixed signal on both AM and SSB to use as a reference point between the two radios for the adjustments. If you have a close friend have him/her throw a carrier your way to use a fixed reference point or find a beacon signal in the 10meter band. You know you have the meters adjusted correctly if they match your good working radio. And also check the higest frequency on your 2995DX the signal meter should be flat 0-1 S units at the most because there is little to no signal noise up there.
    Good Luck--jeo
  • 3,018 Answers
PLL Synthesizer / Oscillator Frequency Alignment:
1. PLL2 - VCO Voltage: A. Set radio to 24.890 MHz, AM RX mode, connect multimeter to TP10. Adjust L14 for 1.0 Vdc ± 0.1. B. Set frequency to 29.699 MHz, AM RX mode, connect multimeter to TP10. Adjust L14 for 4.5 Vdc ± 0.1.
2. PLL1 - VCO Voltage: A. Set radio to 24.890 MHz, AM RX mode, connect multimeter to TP10. Adjust L13 for 1.0 Vdc ± 0.1. B. Set frequency to 32.000 MHz, AM RX mode, connect multimeter to TP10. Adjust L13 for 6.5 Vdc ± 0.1.
2. AM Frequency: Set radio to AM RX mode, clarifier to 12 o'clock,. Connect frequency counter to TP16. Adjust VC2 to 10.1 MHz ± 10Hz.
3. VCO Output: Set radio to 28.000 MHz, AM RX mode, connect oscilloscope to TP3. Adjust L17 to 38.6950 MHz (maximum output).
4. AM OSC: Set radio to AM TX mode, modulation off, connect frequency counter to TP5. Adjust L18 to obtain 10.6950 MHz ± 10Hz.
5. USB OSC: Set radio to USB TX mode, modulation off, short TP6 to ground, connect frequency counter the TP5. Adjust L20 to 10.6975 MHz ± 10Hz.
6. LSB OSC: Set radio to LSB TX mode, modulation off, connect frequency counter to TP5. Adjust L19 to 10.6925 MHz ± 10Hz.
This completes this stage of the alignment procedure.
Receiver Alignment:
1. Receiver Setup: Put the mode selector on AM, the RF gain fully clockwise (maximum gain), squelch to minimum (unsquelched), volume at 2 o'clock, set frequency to 28.295 MHz, and NB/ANL to OFF. Connect signal generator set at RF carrier frequency of 28.295 MHz, AM modulated with a 1 KHz audio tone at 30% modulation level.
2. AM Sensitivity: Connect a SINAD meter to the external speaker jack. Adjust L3, L4, L6, L7, L8, L10, L11 and L12 for best SINAD. Increase the RF generator to 1mV RF carrier level. Adjust L3, and L4 for minimum distortion. Verify that the receiver AM sensitivity is better than 0.5µV for 10 db SINAD.
3. FM Distortion: Change the RF generator to the FM mode, 1mV RF carrier level, FM modulated with a 1 KHz audio tone ± 3 KHz modulation level. Adjust L5 for minimum distortion.
4. USB Sensitivity: Turn off the audio modulation of the RF generator, and change it's frequency to 28.296 at an RF carrier level of .5 µV. Set radio to USB RX mode. Adjust L11 and L12 for audio output greater than 2V.
5. LSB Sensitivity: Keep the audio modulation of the RF generator off, change frequency to 28.294 at an RF carrier level of 1mV, set radio to LSB mode. Adjust L11, and L12 for audio output greater then 2V.
6. NB Adjust: Set radio to 28.305 MHz AM RX mode, NB-ANL/OFF switch to ON, adjust RF generator to 28.305 MHz with an RF carrier level of 1mV, AM modulated with a 1 KHz audio signal at 30% modulation. Connect a digital voltmeter to TP1 (R11). Adjust L1 and L2 for DC Voltage to max ( 1.3V ).
7. AM Scale Meter: Turn NB-ANL switch to OFF, SWR/S/RF switch to S/RF position, set radio frequency to 28.305 AM RX mode, RF signal generator setting 28.305 MHz with a carrier level of 100 µV, AM modulated with a 1KHz audio signal at 30%. Adjust VR1 so that bar graph reads 6 bars.
8. USB Scale Meter: SWR/S/RF switch to S/RF position, set radio frequency to 28.495 MHz USB RX mode, RF signal generator setting 28.496 MHz with a carrier level of 100 µV, no audio modulation. Adjust VR2 so that bar graph reads 6 bars.
9. AM Squelch: Set radio frequency to 28.495 MHz AM RX mode, SQ control fully clockwise, RF signal generator setting to 28.495 MHz , RF carrier level at 1 mV, AM modulated with a 1 KHz audio signal at 30%. Adjust VR4 very slowly until squelch noise just goes off.
10. SSB Squelch: Set radio to 28.495 MHz USB RX mode, SQ control fully clockwise, RF signal generator setting to 28.496 MHz , RF carrier level at 1 mV, with audio modulation. Adjust VR3 very slowly until squelch just goes off.
This completes the Receiver stage of the alignment procedure.
Transmitter Alignment:
1. Driver BIAS: Remove the "Shorting PCB" from TP7, TP8, and TP9. Set radio to USB mode, connect current meter to TP9 (+) and TP8 (-). Adjust VR11 to obtain 50 mA.
2. DRIVER BIAS: Set radio to USB mode, connect current meter to TP9 (-) and TP7 (+). Adjust VR13 to obtain 10 mA.
3. SSB & AM RF Power: Reconnect the "Shorting PCB" from TP7, TP8, and TP9. Connect a watt meter and a 50 Ohm load to the antenna connector, set radio to 28.495 MHz, USB mode, mic gain to maximum. Inject 30 milivolts of 1 KHz audio into the audio input pin of the mic jack (pin 2). Set SSB power control (VR12) to full counter clockwise position (maximum power position). Adjust L18, L33, L40, L42, L43, and L44 to obtain maximum power output. Adjust SSB power control (VR12) to 21 watts peak RF power output. Change mode to AM Adjust VR15 to obtain 10 watts RF power output.
4. Power Meter: Set radio to 28.495 MHz, AM mode, mic gain control to maximum, meter switch to S/RF and key the transmitter. Adjust VR10 until the RF meter reads 10 watts
5. TX AM Modulation: Set radio to 28.495 MHz, AM mode, mic gain control to maximum, key the transmitter. Inject 30 milivolts of 1 KHz audio into the audio input pin of the mic jack (pin 2). Adjust VR17 to 100% modulation.
6. CW Side-Tone Signal: Connect a voltmeter directly across the speaker, key the transmitter using the CW jack in the rear of the radio. Adjust VR9 to obtain 200mV across the speaker.
This completes the Transmitter stage of the alignment procedure.
Posted on Mar 17, 2011
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
Mar 14, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Cable box only works during evening hours.
You need to schedule a service call to meter the feed to the house. You signal is lowest during the day since everyone is taking up bandwidth for internet access, thus dropping the signal to unusable levels. Have them meter the feed from their tower to your main panel then from your main panel to the modem or any box. Hope this helps
Sep 20, 2009 | Pioneer VSX-406 Receiver
Alinco DR-635. On two meters, there is no received audio.
I think your 2M section has a dead FET in the receiver front end. The FET transistors are bad about being destroyed by ESD, as they are not gate protected. This is a repair shop job, unless you are very good with repairing surface mount technology. The 635 is a good rig, well worth the repair costs. Consider using a factory repair shop, to get the job done right. There is an Alinco group on Yahoo Groups, join them and ask where to send your radio for repair. They will know who is reliable enough to trust your treasured radio to for repair.
Good Luck,
Longshorts.
Jul 06, 2009 | Radio Communications
Radio signal strength not very good
It is due to the vehicle antana. you need to purchase a antana booster. hook it to a 12v power plug antana from car to one side of booster and radio to other side. this will increase signal from car antana to radio and should fix problem. most boosters can be found at any car audio or truck stop and run from$10.00 - $25.00 good luck
May 21, 2009 | Goodmans CD car radio GCE358MPT CD Player
Lazy signal needle
Probably NOT the potentiometer that assists the meter. I would suspect a abad needle in the meter. I'd see if you can get to the adjuster screw on the meters front. Many times it's hard or impossible to adjust due to the way it's mounted.
Jan 12, 2009 | Midland 4001 40-Channels Base CB Radio
Rci 2950 no audio period rx or tx
Check TR38 I have seen caps in the circut
go bad more then once if you have a schematic you should be able to find it if one
is bad,a capasator meter would help but you
can check them with a ohm meter.
Good luck.
Nov 21, 2008 | Radio Communications
Cobra 2000gtl no sound comeing out but will talk on am and ssb can you help
Because you have transmit, more than likely your audio section is OK as much of it is shared with the receive side. A final test of the audio section is to check out the PA function. If it works most of the audio section has been tested.
The signals for the meter movement and receiver sound are developed in the audio detector circuit (diodes D21 and D22) just past the I.F. stages (Transistors TR16, TR17, and TR18). I have seen these diodes fail. They are frail little guys, but are inexpensive. I would recommend replacing them first. Pay particuliar attention to which way the band on the diode is positioned and limit your soldering time. If that does'nt rectify the problem, (no pun intended) you can look at the transitors.
By the way, MOVE that second test radio farther away or you could overload the front end of your Cobra creating even more problems. Good Luck, 302
Nov 26, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Ranger RCI-2995DX Base Scanner Logo
461 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
