I have an Epsom Stylus C66printer. An ink cartridge needed changing, which I did ok, now when I wish to print a document nothing happens. The printer when switched on goes through its set up routine, then nothing at all. LL connections are fine, and until the cartridge change everything was fine. What do I do now, please
  • wheatystraw Aug 01, 2008
    Cartridge was correct one and was inserted properley
1. Correct replacement cartridge? 2. Inserted correctly?
Posted on Aug 01, 2008
How to persuade my epsom stylus DX6050 printer to accept non epsom ink cartridges
i have a continious ink setup on epsom dx5060 system is telling me to change the cartridges they have reset chips in them????
Jan 21, 2011 | Epson Stylus DX6050 All-In-One InkJet...
How do i change nk cartridges n my epsom stylus 4050
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Wait a few seconds, and the print-heads will slide to a position
where each ink-cartridge can be removed.
Push down on a cartridge, to "unlock" it from its holder, and slide it out.
Jul 30, 2010 | Epson Stylus NX400 InkJet Printer
How to change ink on a epsom stylus 215 printer
Hi Eileen!
Use the instructions here to change your printer's ink cartridges.
(Use the arrows on top to switch pages until you get to "Remove and Install Cartridges").
Best regards,
Pelu.
May 10, 2010 | Epson Office Equipment & Supplies
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access...
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
I've changed the ink cartridge in my epsom printer but it wont print, what can i do
If you haven't printed a lot lately, your print head might clogged. Here's what you can do: go to "print", then "properties", then "maintenance", and find the option "head cleaning". You will hear strange sounds coming from inside your printer, nothing to worry about, the printer is just trying to push the ink through the print head. In the end, the printer will print 4 colors: black, yellow, magenta and cyan. If the colors seem ok to you, you have fixed your problem. If not, repeat the process several times (just bear in mind that cleaning the head uses a lot of ink).
Hope that helps, and if it doesn't, please let me know, would love to help find a solution to your problem!
Mar 05, 2010 | Epson Stylus CX5400 All-In-One InkJet...
My Epsom Stylus C45 was running low on black ink. The second button on top was blinking red because I tried to print. So, I opened the cover and pressed the second button to get the cartridge out, and...
Yes you can still move the inks first put the power off on and then you go to look very close to where the cartridges are and at the bottom of the inks you see a little leaver you can pull this up and at same time slide the ink cartridges to the middle so you then can change them but do the careful.
All the best: Pineworks
Feb 04, 2010 | Epson Stylus C86 InkJet Printer
Have an Epsom stylus color 440. will not print
I'm trying to do a print nozzle check on my Epson Stylus Color 440 printer that I have but a pop-up box say "Error, can't print". Why is this?
Oct 06, 2009 | Epson Stylus Color 440 InkJet Printer
EPSOM STYLUS C62 COLOUR PRINTER PROBLEM! HELP! URGENT!
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Feb 23, 2009 | Epson Stylus C62 InkJet Printer
Magenta ibk problem
Have you tried running head-cleaning cycles? If not, try 2 or 3 followed by a nozzle check and see if magenta starts to appear. If this still produces no magenta print, or you've already tried this with no success, report back.
Feb 01, 2009 | Epson Stylus C84 InkJet Printer
Epsom printer dx7450
you could have one of several problems here.
i,d suggest printing several test pages, and observe whether the red comes through after this.
if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
finally if you have the original software installed for the printer, try a head cleaning operation.
Mike @ Compurepair.
Jun 22, 2008 | Epson Stylus C60 InkJet Printer
47 people viewed this question
jasbo
jasbo
