Question about Black & Decker Tools & Hardware - Others
I need a exploide view of a Black & Decker Belt Sander--Type F--U 345 Professional. It have a bad ball bearing in it and I want to dismantel it. What dose this service cost, I dont mind paying for it, if it is good information.
  • Black & Decker Master
  • 43,501 Answers
There is a 340 sander but no 345...here is a listing off B&D sanders and there are exploded views for them...
http://www.ereplacementparts.com/black-and-decker-sander-parts-c-4167_4300.html
heatman101
Posted on Mar 14, 2011
Black & Decker Belt Sander suddenly stopped working.
Probably not.
It may have just had a part break inside, like the on-off switch, or one of the wires to one of the brushes, etc., etc.
I buy these regularly, and they are inexpensive, which also means they are made of inexpensive ( cheap) parts.
It wouldn't hurt to take it apart, knowing it may not be repairable. Sometimes parts are available on-line.
Be blessed.
Mar 10, 2013 | Black & Decker BR318 3" x 18" Belt Sander
I have a Black and Decker Sander, model # 5.2 A and I cannot find a motor belt for it. The belt that broke has "made in China" stamped on it and the numbers 110XL 031 stamped on it.
You might try Dewalt. I have a Black & Decker weed eater that had a broken belt and I had to order it from Dewalt. I was told that they had some kind of merger. Ordered it and it worked just fine.
Mar 01, 2011 | Black & Decker BR300 3''x18'' Belt Sander
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Black & Decker 3X21'' belt sander (#7447)- pushed front roller in to put on new belt, can't get it to spring back out. Jim in Flippin
I have one of those and I just smack the front roller ahead with a brass or plastic hammer. I hit the movable bracket that the roller is attached to. It takes a pretty stout whack to do it though. hope this helps you
Jan 14, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
Broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Jul 15, 2009 | Black & Decker Tools & Hardware - Others
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
I have a type 2,#92 heavy duty sander,length of right angle sander is 14".. approx 35 years old............need brushes. whee can I find these please...
First try Black & Decker Serves Department. At some Hardware stores (ACE, True Value, etc)they stock brushes in the back room.
Jun 12, 2009 | Black & Decker 4.3A 6" Heavy Duty Right...
Need belt for black and decker sander 110 xl 031
The belt from Jason 110XL031 is Identical in size and apperance.
Jan 07, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Tools & Hardware - Others Logo
87 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Rabbit Brains
Rabbit Brains
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
