Question about Siemens Washing Machines
Residual water/ conditioner in care product drawer
    Brigadier General:
  • 6,277 Answers
Although you do not say which model it is, this is a common problem with many machines.
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Posted on Mar 14, 2011
Excell 7 VarioPerfect: fabric conditioner compartment will not drain
perhaps you need to contact Bosch website for tech support
Sep 21, 2016 | Bosch Washing Machines
Why does the fabric conditioner compartment stay full of water after wash has finished ?
The compartment has to be flushed to prevent conditioner residue from hardening and clogging it.
Apr 16, 2016 | Washing Machines
Hi. the drawer into which the fabric conditioner is poured, is not being flushed, i.e conditioner remains in drawer. Any idea how I unblock the water inlet ? Thanks
usually the drawer has a plastic tube with cap in it.remove the small cap and clean/wash with water until the residues of the previous conditioner is cleared. then put back the small plastic cap. hopefully it will drain properly on your next use of conditioner
Sep 03, 2015 | Washing Machines
I have a bush wm-1260b washing machine and the pull out drawer has the three slots for which the midddle slot you put your fabric softener in. After every wash that middle slot fills with water. We can not...
I had the same problem and just searched online and found your question. I have just taken the drawer out by pulling it out as far as it normally goes, then by pressing down on the blue top of the middle (conditioner) drawer the drawer will then pull out all of the way. Rinse the drawer under the tap and scrub off all gunk especially from the middle drawer and in and around the blue component. Reassemble and then push drawer back into the machine, remembering to press down on the blue part in order to push the drawer all the way back into place. I suggest watering down the conditioner a little when putting it in as I think that some are too thick and will leave residue, causing the build up of dried conditioner and the the filling up of water. This seems to have solved the problem and I think the manual does say to clean regularly, which I think I will start doing!
Jan 30, 2011 | Washing Machines
Aquarius WM32. Will no longer use the conditioner from the dispenser drawer. dapchiles@talktalk.net
There is probably a blockage in the drawer.
Remove drawer and thoroughly clean all parts, making sure there is no residue of powder or conditioner in any of the compartments.
Nov 20, 2010 | Hotpoint Washing Machines
Water coming out of dispenser draw when starting rinse cycle
Make sure that the conditioner drawer is free of old soap residue because it cannot syphon out on the rinse cycle causing it to overflow.Hope this helps.
Good Luck.
May 09, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Zwf 1221 w fabric conditioner wont go through machine
Sometimes the little drawer for the conditioner can get clogged with soap residue take out drawer by pressing on release tab in drawer,take to sink pull out plate above syphon holes make sure all holes are clean also under small plate clean out recess.The other check is make sure you have good water pressure and clean the little holes above drawer with an old toothbrush and a bent piece of wire.There may be a solenoid not working all these need looking at.Hope This has been helpful.
Good Luck
May 05, 2010 | Zanussi Washing Machines
My Washing Machine is emptying the Fabric conditioner too early
Washing Machine has started to empty the Fabric Conditioner high water or blokage in draw
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 05, 2009 | Washing Machines
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Nov 03, 2008 | Miele W865 Front Load Washer
Washing Machines Logo
251 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
