Question about Sport & Outdoor - Others
I need a manual for Double Horse 9053 Volitation R/C Helicopter
4 Suggested Answers
  • 18 Answers
SOURCE: i could not control my rc helicopter
Please describe your problem in more detail. Are you able to get lift? If it isn't doing anything at all then there are two things to consider:
1.) This model is known to show a full charge when in fact the battery is receiving no charge at all. Contact the manufacturer for assistance.
2.) There's a safety feature that won't allow the motor to engage until the gyro is locked. Be sure to power on the remote first then the helicopter.
If you are getting lift but can't keep it steady then you may have a balance bar issue. If you've encountered a crash or two then this is very likely.
You may want to consider joining RCdiscuss.com. They have an extensive network of RC enthusiasts with valuable knowledge and resources.
Posted on Jun 24, 2010
SOURCE: instruction manual for double horse
i need the owners manual for the " volitation 9053 helicopter "
Posted on Mar 14, 2011
SOURCE: Can someone tell me what might be wrong with my
it might be the controller that is broken. but it might be if he crashed it too much it could be broken. i had the same problem with my heli but i crashed it a couple times and now it does the same as yours hopefully im some help for u
Posted on Dec 09, 2011
Double Horse 9053 Volitation Gyro cuts out
Most likely a fault with the PCB circuit board and needs replacing. Also check the motors and rotors are running freely as this could also cause the PCB to trip off.
Kind regards, julian.
rccontrolfreak.co.uk
Dec 18, 2013 | SYMA Toys industrial 9077 Double Horse...
THE BOTTOM ROTORS DO NOT SPIN
1) test the button for open or faulty. However clean it with contacts cleaner solvent.
2) Resolder any wires from the button by dry join.
3) Tight the wires from rotor and resolder the dry join from rotor and test again.
You must sure that batteries is FULL charged, otherwise put a new ONES HYBRID ALKALINES. VERY IMPORTANT
God bless you
Jan 25, 2013 | Double Horse 9053 Volitation Remote...
9053 will not take off
Lift is a function of the aerofoil. See that heptr blades are not bent or you or someone else have not tried to straighten the blades. They are at a specific angle to provide the required lift.
Apr 24, 2012 | xheli 9053 Outdoor Volitation Metal...
My helicopter 9053 will not connect to my controller
The receiver is not binding to the transmitter. Make sure the batteries are in good shape in transmitter. I'm assuming it's a 2.4GHz radio frequency.
When you are about to fly, turn transmitter on first after 4-5 seconds turn
heli on or plug battery in on heli. In the manual there should be a page describing radio binding. It will describe on what gimbles to move and
in certain sequences to complete the process. When the light on transmitter stops flashing means the binding process is complete.
Hope this helps.
Dec 15, 2011 | xheli 9053 Outdoor Volitation Metal...
Volitation 9053 flashing green light when charging brand new out the box
I have the same problem. I watched the video on helix.com and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
Nov 17, 2011 | xheli 9053 Outdoor Volitation Metal...
How remove to balance bar of a toy helicopter 9053
Hi
my 9053 runs for 10secs then cut out, but the red light on the board flashes
Mar 14, 2011 | SYMA Toys industrial 9077 Double Horse...
Instruction manual for double horse 9053 helicopter
Dec 20, 2010 | Toys
My 9053 volitation wont lift ground, i checked top blade it's not loose from metal shaft, it also wants to spin heavy to the right in circles. I just it so I'm learning
Had a similar model lasted 10 mins i broke this little plactic holder that seperates the blades i bent it the slightist bit and boom never flew again
Oct 16, 2010 | xheli 9053 Outdoor Volitation Metal...
Hi my helicopter is 9053 , my helicopter working but dont rise , meanwhile it s charging is full , please help me for how to rise many thanks
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
Jun 09, 2010 | xheli 9053 Outdoor Volitation Metal...
Sport & Outdoor - Others Logo
143 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
