Question about GE Refrigerators
I have a GE Profile Bottom Freezer Refridgerator. Everything I put in the fridge freezes. When I increase the temperature, it stays low.
  • 1,543 Answers
Make sure you do not have items blocking air flow to the temperture sensor at the top left side of the refrigerator. Another thing to check would be air leakage at the air duct at the bottom back of the fresh foods section. Also, at that air duct, make sure there is an electrically activated dampener door inside (I've seen them missing), and that the damper door is not broken.
Posted on Mar 14, 2011
GE Profile Brita Fridge. Have setting down as low as possible and crisper foods continue to freeze. How can I fix that?
You need an internal digital thermometer to see if 1 is the coldest or the hottest. If you turn it to 6 and the temperature remains the same, the thermostat is faulty.
If 1 is the warmest and it continues to freeze crisper foods like lettuce, you need a new thermostat. Your ideal temperature is between 3 and 4' Centigrade at the coldest part, usually above the bottom shelf.
Aug 23, 2016 | GE Refrigerators
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
My ge profile bottom freezer refregrator is freezing everythin
is it freezing everything in the fridge as well? if so i had the same problem with my side by side fridge a while back. the appliance repair man told me to vaccuum the fridge underneath and all the other parts behind i did and it seemed to work well after that. also have you checked your temp controlls in the fridge.
Jan 02, 2013 | GE Refrigerators
I can't seem to get the temperature to increase, I push the buttons and it continues to go back down every time. This has been going on for a week! Any suggestions?
you say you want the temperature to "increase" do you mean WARMER...ideal temp for fridge is between +2C and +5C and for a freezer -18C or colder
Sep 12, 2010 | GE Profile Stainless Bottom-Freezer...
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile TCC18 Refridgerator freezes Up regularly.
I had the same problem. I changed the defrost thermostat and that has solved the problem. Just to make sure the problem is not recurring I drilled a small hole in the back of the plastic drain(behind the fridge) so that I can put a long screw driver inside to determine if there is any ice build up. None so far after 3 weeks.
Feb 28, 2009 | GE GBS22HCP Bottom Freezer Refrigerator
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
