Question about Nintendo Wii Console
How do i set up the connections - Nintendo Wii Console
    Problem Solver:
  • 10 Answers
Make sure you're home internet is a high-speed, wireless connection with router. Go to the Wii's menu and go to the settings on the lower left corner of the screen. Look for the internet option and then look for connection settings. Select Connection 3 and then 'wireless connection'. The Wii will then scan for an access point, and in this case, your internet's name should show up. Select your name and then save.
Posted on Mar 14, 2011
  • 49 Answers
Following this tutorial, you should be able to set up your device - link.
If you found this answer helpful, please rate it.
It will help me and other users that are searching for help.
Hi, Having problems connecting the PS3 to the Internet?
There are two ways to connect to the internet there is Wireless or Wired connection here is how to do both:WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet Connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of Internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home internet access point requires a password enter the password when prompted and save your settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
Tip
Connect PS3 to the Internet
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Back to top
Wireless Connectivity:
  • A cable modem and a router
  • Access point (Not necessary if using a wireless router with built-in wireless functionality)
  • Settings information for the access point (SSID, WEP key, WPA key)
When you try to connect wirelessly to the Internet, First adjust the network settings. These settings may change depending on the type of access point and the network environment you are in.
The following instructions apply most of the network configurations.
  4. Select "Wireless", press the x_button.jpg button.
  5. Select "Scan", press the x_button.jpg button.
    The system will search for access points within range and display them as a list.
  6. Select the access point that you want to use, press the x_button.jpg button. (An SSID is a code or a name that is assigned to the access point. If you have no clue which SSID to use or if the SSID is not displayed, contact the person who set up or maintains the access point.)
  7. Confirm the SSID for the access point, press the right button.
  8. Select the security settings as necessary, press the right button.
  9. Enter the encryption key, press the right button. (The encryption key field will display an asterisk (*) for each character you enter. If you do not know the key, contact the person who set up or maintains the access point).
  10. Select Easy or Custom and adjust the settings.
on Feb 20, 2010 | Video Game Consoles & Games
How to connect PS3 to the internet?
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and saveyour settings.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
No puedo conectar mi ps3
WIRELESS (WIFI):
Feb 19, 2011 | D-Link DIR-300 Wireless Router
Can i hook up my ps3 to a wired internet
Wired Connectivity:
  • A cable modem
Sep 13, 2010 | Sony Playstation 3 (PS3) Console
Can not connect to internet Do I need to connect directly to the modem. i have wireless Interent in my home but th emodem is 3 rooms away. Should I get a second modem?
here try this and remember to leave a testimonial.
Wired Connectivity:
  • A cable modem
  • Ethernet cable. (Available with the PS32_bing.gif)
  • When you have a wired connection to the Internet2_bing.gif, it is not necessaryto adjust any of the default settings. (It is done automatically). Ifyou aren't able to connect with the default settings, follow theinstructions to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  1. Select "Internet Connection Settings", press the x_button.jpg button.
  2. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  3. Select "Wired Connection", press the x_button.jpg button.
  4. Select Easy or Custom and adjust the settings.
    • Wireless Connectivity:
When you try to connect wirelessly to the Internet, First adjust thenetwork settings. These settings may change depending on the type ofaccess point and the network environment you are in.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
I cant connect to the internet
Playstation 3: How to setup your Internet connection This article helps you in setting up the Internet connection for Playstation 3 To enjoy the online capability of Playstation 3, you need to connect it to the internet. You can do it in two ways:
  1. Wired Connectivity.
  2. Wireless Connectivity.
Wired Connectivity:
  • A cable modem
Back to top
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your provider
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
Can u please help me connect my ps3 to play games online i have usb modem connected to laptop, with ethernet cable connected to ps3 from laptop......... i live in australia
Wired Connectivity:
  • A cable modem
Back to top
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
How do i jook up my playstion 3 to the internet via time warner wired connection
1st Step: Setting up the Internet Connection
When making a wired connection to the Internet, you do not need to adjust any of the default settings. If you cannot use the default settings to connect, follow the instructions below to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, and then press the X button.
  • Select "Internet Connection Settings", and then press the X button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the X button.
  • Select "Wired Connection", and then press the X button.
  • Select "Easy" or "Custom" and adjust settings as necessary. (Easy is recommended)
  • Follow the on-screen instructions to adjust the required setting.
Easy: Basic settings are set automatically.
Custom: You can manually enter detailed settings information.
Here's a diagram set up to PS3 wired internet connection
You can take a look at the connection diagram here
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to work with my wireless broadband
Settings > Network Settings > Internet Connection Settings (wireless connection)
Internet Connection Settings (wireless connection) This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Confirm that an Ethernet cable is not connected to the PS3™ system.
3.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings) in the home menu.
4.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
5.
Select [Easy].
connectwired002.jpg 6.
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
connectwireless002.jpg 8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
connectwireless003.jpg 9.
Check the SSID for the access point.
10.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
connectwireless004.jpg 11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
connectwireless005.jpg When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12.
Save your settings.
13.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
14.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Hints
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Mar 12, 2008 | Computers & Internet
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
