Question about Lorex L154-81
Lorex L154-81 Hi would you happen to know why the clock doesn't work? I put the time and set it but it never takes off. Could this be a defect?
  • 3 more comments
  • sivart212 Oct 02, 2008
    Clock dosent work... battery is good, very strange.
  • Anonymous Nov 29, 2008
    Clock does not work
  • tim10000 Jan 15, 2009
    My clock is stuck too.  Changing year doesn't help.  The display on the main screen shows an asterisk (*) to the right of the time/date -- what does it mean.  The time is just frozen at whatever I set it to...
  • jhbANUELOS Jan 27, 2009
    I have the same problem. I set the clock and it does not tick...
  • Anonymous Mar 03, 2009
    my clock won't run
Mine is doing same thing...must be a defect
Posted on Aug 02, 2008
To me it looks like a bug, if I change the year back to 2003 the clock works again...
Posted on Oct 18, 2008
98 GTP, clock not working how to fix
"Not working" covers a lot of ground. Is it dead? is the display incorrect? Do the controls not work? I would spend some time making sure the clock is defective before progressing.
Assuming it is electric (no '98 car should be mechanical, should it?) check the fuse first. It is probably fine, but it is the easiest check you can make. If the fuse is good and the wiring seems intact (mouse hasn't eaten through a wire, etc. - don't laugh, it happens), then the clock itself is probably bad. I would find a replacement in a junk yard that allowed me to take my own parts out. In getting the replacement clock out you will learn how to install it in your vehicle. You could also check your library for a service manual for clues.
Verify your replacement clock works before tearing your dash apart to replace your defective unit. I must say, dashboard work is some of my least favorite repairs. Anyway, install the new one, put your car back together, hide the parts that didn't fit putting it all back, and you should be good to go. Your dealer could also replace the clock I would think, but the $$ might make me think I could live with the problem.
Nov 06, 2012 | 1998 Pontiac Grand Prix
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
Kenmore oven won't get hot
hi,,
check the following
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
thank u
rate me
Jul 22, 2009 | Kenmore Kitchen Ranges
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
RCA RP5420 auto set is not working
mine was doing the same thing, it had bad batteries!
Jul 02, 2008 | RCA RP5420 Clock Radio
Setting the clock on a Philips MCB240
hi
will this help
a user guide download and search the clock settings hopefully this will solve it .
PHILIPS MCB240 Micro Hi-Fi
riz.
Feb 26, 2008 | Audio Players & Recorders
Singing bird clock
take batteries out set clock to 12.50 pm then insert batteries and set to normal time. this will then put correct bird sounds with relevant bird.
Dec 31, 2007 | Audio Players & Recorders
Clock loses time
Take daylight savings time in the clock setting. if not, it might be a clock defect in the unit.
Nov 01, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Lorex L154-81 Logo
319 people viewed this question
Top Lorex Televison & Video Experts
Jim London
Jim London
Colin Stickland
Colin Stickland
Are you a Lorex Televison and Video Expert? Answer questions, earn points and help others
